Radio Question 2008 #2858522
12/11/20 01:45 PM
12/11/20 01:45 PM
Bradenton, Fl 34203
Kilroy was here Offline OP
Bradenton, Fl 34203
The CD player stopped working in my 2008 Raider. (It's a Dakota). Ebay has the usual deals.
Two Questions.
#1. Some ads say """“This radio WILL need to be reprogrammed/ or a code from your local dealership""". I called the dealer, ($80), and the service manager was very helpful.
#2. Some ads say ""equipped with a low-speed CAN-BUS system for this radio to work". so how do I know if my truck is High or Low speed Can-Bus?
Anybody replace a radio....without programming it? The radio on eBay has the exact same part #. 05064410AF
John
[/img]eBay Radio Low speed Can Bus
Re: Radio Question 2008 [Re: Kilroy was here] #2858673
12/11/20 07:11 PM
12/11/20 07:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check on ebay for a Dodge radio unlock code service. Much cheaper then the dealer
Re: Radio Question 2008 [Re: Kilroy was here] #2858682
12/11/20 07:33 PM
12/11/20 07:33 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If your CD player is still spinning discs but not playing music, you can take it apart and use alcohol on a Qtip to clean the eye.
Mo' Farts
Moderated by "tbagger".
Re: Radio Question 2008 [Re: Grizzly] #2858801
12/11/20 11:28 PM
12/11/20 11:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could try a cd cleaner disc.
Re: Radio Question 2008 [Re: stumpy] #2858852
12/12/20 09:32 AM
12/12/20 09:32 AM
RWG75
RWG75
Try poking around some sites that are dedicated to the late model stuff. A lot Jeep / Ram sites have a whole section dedicated to hacking the CAN and assorted controllers. Mostly about correcting speedos and other tweaks to the drive line. The car sites are usually bigger on the radio info - adding back up cams, extra screens and head unit swaps. There are a couple software apps that have been floating around for years that will reprogram the radio vin.
Re: Radio Question 2008 [Re: ] #2859333
12/13/20 12:38 PM
12/13/20 12:38 PM
Bradenton, Fl 34203
Bradenton, Fl 34203
Okay thank you for the advice guys I appreciate it.
I bought a used $80 one off eBay. Had the same part number and looked exactly the same.
It was plug and play without any effort.
Thanks again and it works fine..
John
