Ray Barton G2 Hemi Rocker Arms #2857714
12/09/20 04:45 PM
12/09/20 04:45 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Couple questions, do you need push rod oiling when going to these?
Did you gain any HP by going to them?
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2857811
12/09/20 09:01 PM
12/09/20 09:01 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The ones I have used have a spray bar built into the bed plate. They spray UP under the rockers and use feed lines. They were mainly designed to increase the RPM capability.
Re: Ray Barton G2 Hemi Rocker Arms [Re: fbs63] #2857850
12/09/20 09:59 PM
12/09/20 09:59 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Mine are push rod oiled. At least I thought that they were until I read the spray bar comment. Looks like a spray bar right down the middle?
[Linked Image]Untitled by Greg Ault, on Flickr
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2858015
12/10/20 11:04 AM
12/10/20 11:04 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The intake and exhaust geometry can be adjusted separately.
Boffin Emeritus
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2858056
12/10/20 12:42 PM
12/10/20 12:42 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Mine are push-rod oiled - you can go both ways with them - T&D has a new design for the edelbrock Vic Jr head that oils through the block - pretty neat design. They are a very stable rocker arm system - well worth the money!
Re: Ray Barton G2 Hemi Rocker Arms [Re: DoubleD] #2858099
12/10/20 02:03 PM
12/10/20 02:03 PM
Dragula Offline OP
Dragula  Offline OP
How come I do not see the spray bar in yours?
And what ratio's are you guys using?
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2858106
12/10/20 02:25 PM
12/10/20 02:25 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
See the groove under the intake rockers? Thats where the spray bar was on the ones I used. They must give you a choice of oiling style now.
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2858135
12/10/20 04:08 PM
12/10/20 04:08 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
1.6I, 1.55E for me.
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2858380
12/11/20 09:15 AM
12/11/20 09:15 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Because they are push rod oiled - Mega block with bushed lifter bores, crower roller lifters and trend pushrods - I have seen other builds with both spray bars and pushrod oiling - but that seems to me like way too much oil going up top - my rockers are 1.6 ratio
I looked at all of the rocker systems available - and for the small upcharge to Barton - it made sense - if the new T&D system for the Eddie Victors was available when the engine was built - I would have gone with those
Re: Ray Barton G2 Hemi Rocker Arms [Re: DoubleD] #2858494
12/11/20 12:56 PM
12/11/20 12:56 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I decided to pushrod oil with my Barton’s as well. I had Best Machine bush the lifter bores and bought their lifter package to avoid any issues.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2858561
12/11/20 02:34 PM
12/11/20 02:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: Ray Barton G2 Hemi Rocker Arms [Re: polyspheric] #2858865
12/12/20 10:24 AM
12/12/20 10:24 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
where the rocker sweep angle differs from the valve stem angle -
The angles are the same the rocker bed plate is angled at the trunnion - the pattern on these rockers is very tight and centered
Re: Ray Barton G2 Hemi Rocker Arms [Re: DoubleD] #2859004
12/12/20 03:48 PM
12/12/20 03:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The angles are the same?
Care to make s small wager?
Boffin Emeritus
Re: Ray Barton G2 Hemi Rocker Arms [Re: polyspheric] #2859176
12/13/20 12:42 AM
12/13/20 12:42 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Starting angle is the same but don't remain so because of diverging centerlines?
Re: Ray Barton G2 Hemi Rocker Arms [Re: INTMD8] #2859182
12/13/20 01:16 AM
12/13/20 01:16 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: Ray Barton G2 Hemi Rocker Arms [Re: polyspheric] #2859510
12/13/20 05:48 PM
12/13/20 05:48 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have seen similar, but more exagerated, set ups on wedge heads with steel rockers. Rather than run an offset rocker arm, they run a straight arm that is angled so the centerline of the arm is colinear with the valve tip centre to the pushrod tip centre.
When I asked, no one seemed to notice any adverse effects
Alan Jones
Re: Ray Barton G2 Hemi Rocker Arms [Re: Dragula] #2859547
12/13/20 07:49 PM
12/13/20 07:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I've learned nothing from similar past experiments.
My remarks appear to invite naught but objections.
This is the point, historically, where some cynic suggests that I deleted the content because I was wrong. Let's just take that "as read", shall we?
Boffin Emeritus
Re: Ray Barton G2 Hemi Rocker Arms [Re: polyspheric] #2859613
12/13/20 10:20 PM
12/13/20 10:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"The roller tip can only follow the sweep angle, and drags sideways across the stem as the valve opens."
I am far from an expert here, regardless, that observation escaped me. up
Re: Ray Barton G2 Hemi Rocker Arms [Re: jcc] #2868369
01/03/21 08:19 AM
01/03/21 08:19 AM
pa
572charger Offline
572charger  Offline
pa
ive had them on my hemi since 2003 close to 10,000 miles and 300 passes , no problems, best investment for a hemi , mine are spray bar oiled, 245 lbs 600 open pressure still have the same pushrods and rockers on my 1400 hp procharged hemi
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
