Re: Ray Barton G2 Hemi Rocker Arms
[Re: fbs63]
#2857850
12/09/20 09:59 PM
12/09/20 09:59 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Mine are push rod oiled. At least I thought that they were until I read the spray bar comment. Looks like a spray bar right down the middle? Untitled by Greg Ault, on Flickr
[Re: Dragula]
#2858015
12/10/20 11:04 AM
12/10/20 11:04 AM
Posts: 4,206 New York
polyspheric
New York
The intake and exhaust geometry can be adjusted separately.
Boffin Emeritus
[Re: DoubleD]
#2858494
12/11/20 12:56 PM
12/11/20 12:56 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I decided to pushrod oil with my Barton’s as well. I had Best Machine bush the lifter bores and bought their lifter package to avoid any issues.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: DoubleD]
#2859004
12/12/20 03:48 PM
12/12/20 03:48 PM
polyspheric
New York
The angles are the same? Care to make s small wager?
Boffin Emeritus
[Re: polyspheric]
#2859176
12/13/20 12:42 AM
12/13/20 12:42 AM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
The angles are the same? Care to make s small wager? Starting angle is the same but don't remain so because of diverging centerlines?
[Re: polyspheric]
#2859510
12/13/20 05:48 PM
12/13/20 05:48 PM
Posts: 6,142 Melbourne , Australia
LA360
I have seen similar, but more exagerated, set ups on wedge heads with steel rockers. Rather than run an offset rocker arm, they run a straight arm that is angled so the centerline of the arm is colinear with the valve tip centre to the pushrod tip centre. When I asked, no one seemed to notice any adverse effects
Alan Jones
[Re: Dragula]
#2859547
12/13/20 07:49 PM
12/13/20 07:49 PM
polyspheric
New York
I've learned nothing from similar past experiments. My remarks appear to invite naught but objections.
This is the point, historically, where some cynic suggests that I deleted the content because I was wrong. Let's just take that "as read", shall we?
Boffin Emeritus
[Re: polyspheric]
#2859613
12/13/20 10:20 PM
12/13/20 10:20 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"The roller tip can only follow the sweep angle, and drags sideways across the stem as the valve opens." I am far from an expert here, regardless, that observation escaped me.
[Re: jcc]
#2868369
01/03/21 08:19 AM
01/03/21 08:19 AM
Posts: 1,629 pa
572charger
pa
ive had them on my hemi since 2003 close to 10,000 miles and 300 passes , no problems, best investment for a hemi , mine are spray bar oiled, 245 lbs 600 open pressure still have the same pushrods and rockers on my 1400 hp procharged hemi
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
