Who to use for rebuild in KC area
#2855958
12/06/20 11:54 AM
12/06/20 11:54 AM
Posts: 146 Missouri
randavis
Missouri
My 440 has developed a miss, which I believe is due to broken rings (again). I have a spare block, but it will need boring, line boring, decking, etc. from sitting for 30 years under the bench. I am not looking to race it, just occasional spirited driving. Somewhere in the neighborhood of 450 to 500 hp. I am looking at either E-Street or 440 Source stealth heads. I will use the Torker II and the Holley Sniper from my old engine. I'll need rods and pistons and a cam package.
My old machine shop has changed hands and I am not sure about the quality of work coming from there. Most of the people I know run GM. Their guys don't know Mopar.
Who would be a decent shop to work with in the Kansas City metro area?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Who to use for rebuild in KC area
[Re: ksj]
#2856023
12/06/20 01:25 PM
12/06/20 01:25 PM
Posts: 146 Missouri
randavis
Missouri
I've heard some negative comments about those guys. They are close to my home. I guess I'll go talk to them and see how I feel then. I have to get the wife on board, so that may take a while. Anybody else?
Edit: After looking at his FB, all I see are GM and one Ford. I would like to find someone who does a bunch of Mopars.
[Re: randavis]
#2856074
12/06/20 02:49 PM
12/06/20 02:49 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
After looking at his FB, all I see are GM and one Ford. I would like to find someone who does a bunch of Mopars. Whats the theory behind this? Is there something magical that must be done to bore, hone, and line hone a Mopar block that GM and Ford guys don't have to do? My opinion is that an engine is an engine and any machine shop that does quality work should be able to do what you need, its not a super stock engine you are building.
[Re: randavis]
#2856076
12/06/20 02:53 PM
12/06/20 02:53 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
How close is Patterson racing to you? I don't know but I think they are in Kansas some where ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: Cab_Burge]
#2856121
12/06/20 03:57 PM
12/06/20 03:57 PM
Posts: 4,705 Wichita
GY3
Wichita
How close is Patterson racing to you? I don't know but I think they are in Kansas some where About 2.5 hours away from him. They are in Augusta, Ks.
[Re: GTS340]
#2856179
12/06/20 06:49 PM
12/06/20 06:49 PM
Posts: 146 Missouri
randavis
Missouri
GTS340: Whats the theory behind this? Is there something magical that must be done to bore, hone, and line hone a Mopar block that GM and Ford guys don't have to do? My opinion is that an engine is an engine and any machine shop that does quality work should be able to do what you need, its not a super stock engine you are building.
I would think a shop that did a lot of Mopars knows what works and what don't. They also may have used parts in stock. Also, they have experience with Mopars and can recommend different options that arre proven. Just my thought.
[Re: hemi-itis]
#2856197
12/06/20 07:15 PM
12/06/20 07:15 PM
moparpollack
Lil Herman
Lil Herman
85086
He's not in the KC area. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: galen]
#2856279
12/06/20 10:04 PM
12/06/20 10:04 PM
Posts: 3,589 Topeka Kansas
ksj
Topeka Kansas
Not sure if this place in Lawrence KS is still in business or not but they know mopars. Automotive Machine and Performance, 715 SE 22nd Street.785-843-9333. Pat Forsyth is the owner
