Crimp fitting adapter ferrules #2852520
11/28/20 12:28 PM
11/28/20 12:28 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I'm assuming that there is such a thing.
Scenario... I am running an 18G ground wire from the tach to the engine block, or battery negative. I need a larger ring for the bolt to go through.
I think that there is an "adapter" that will slide into the 14G terminal and allow for 18G wire to be snugly crimped in versus REALLY crimping the 14G terminal onto the 18G wire.
Sure I could look for and buy the correct ring terminals and but, geezus, my terminal box is already full as hell without getting a bunch more ring terminal sizes that I will maybe use every 5 years.
I've been looking online but haven't come up with what I think that I might need.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Crimp fitting adapter ferrules [Re: cdstl] #2852535
11/28/20 01:04 PM
11/28/20 01:04 PM
moparx Offline
moparx  Offline
i have a bunch of 18ga ring terminals for 1/4" and 5/16" bolts.
will either of those sizes work ?
i haven't looked into whether an uninsulated 18ga butt connector would fit into a 12ga ring or not. [you would have to cut it in half to get the right length.
in any event, if i have something that will work, or i can whip something up, PM me your address and i'll drop a couple in the mail for ya. gratis.
beer
Re: Crimp fitting adapter ferrules [Re: cdstl] #2852538
11/28/20 01:08 PM
11/28/20 01:08 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Just stick another piece of wire in the terminal along with your 18g.
Re: Crimp fitting adapter ferrules [Re: moparx] #2852634
11/28/20 04:41 PM
11/28/20 04:41 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
beer
I'm actually ok with what I have going on. I wasn't sure if the item that I'm talking about even exists, but if they do I'll pick up a few.
Thanks for the offer.
Re: Crimp fitting adapter ferrules [Re: cdstl] #2852752
11/28/20 10:24 PM
11/28/20 10:24 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I just strip extra length and double it up into the lug.
Re: Crimp fitting adapter ferrules [Re: slantzilla] #2852809
11/29/20 07:04 AM
11/29/20 07:04 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
This ^ is one option. If you have something else that needs an 18ga ground, put it in the same terminal.
2 18ga equals 1 14ga.
Angry white pureblood male
Re: Crimp fitting adapter ferrules [Re: ruderunner] #2852827
11/29/20 09:59 AM
11/29/20 09:59 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Yes, they do make ferrules just for that purpose, and as said earlier, you can also fold the wire in half to double up it's size, or add a second wire and cut it off. These are all approved methods.
Re: Crimp fitting adapter ferrules [Re: 375inStroke] #2852863
11/29/20 12:15 PM
11/29/20 12:15 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks.
Re: Crimp fitting adapter ferrules [Re: cdstl] #2852899
11/29/20 01:00 PM
11/29/20 01:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just solder it up, I never just crimp only
Re: Crimp fitting adapter ferrules [Re: cdstl] #2852907
11/29/20 01:15 PM
11/29/20 01:15 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've done this several times using brass, or better copper. cut, drill and, bend the spade portion up slightly for easier access.
pm me if you need one made up in the spirit of giving.
Re: Crimp fitting adapter ferrules [Re: srt] #2852913
11/29/20 01:29 PM
11/29/20 01:29 PM
moparx Offline
moparx  Offline
i did a test fit yesterday, and an 18ga butt connector, the kind with no insulation, fits perfectly inside a 12ga ring terminal.
you can then crimp, solder and heat shrink the connection with ease.
beer
