I'm assuming that there is such a thing.
Scenario... I am running an 18G ground wire from the tach to the engine block, or battery negative. I need a larger ring for the bolt to go through.
I think that there is an "adapter" that will slide into the 14G terminal and allow for 18G wire to be snugly crimped in versus REALLY crimping the 14G terminal onto the 18G wire.
Sure I could look for and buy the correct ring terminals and but, geezus, my terminal box is already full as hell without getting a bunch more ring terminal sizes that I will maybe use every 5 years.
I've been looking online but haven't come up with what I think that I might need.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
