Crimp fitting adapter ferrules
#2852520
11/28/20 12:28 PM
11/28/20 12:28 PM
Posts: 1,487 STL
cdstl
STL
I'm assuming that there is such a thing.
Scenario... I am running an 18G ground wire from the tach to the engine block, or battery negative. I need a larger ring for the bolt to go through.
I think that there is an "adapter" that will slide into the 14G terminal and allow for 18G wire to be snugly crimped in versus REALLY crimping the 14G terminal onto the 18G wire.
Sure I could look for and buy the correct ring terminals and but, geezus, my terminal box is already full as hell without getting a bunch more ring terminal sizes that I will maybe use every 5 years.
I've been looking online but haven't come up with what I think that I might need.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Crimp fitting adapter ferrules
[Re: cdstl]
#2852535
11/28/20 01:04 PM
11/28/20 01:04 PM
Posts: 19,355 north of coder
moparx
i have a bunch of 18ga ring terminals for 1/4" and 5/16" bolts. will either of those sizes work ? i haven't looked into whether an uninsulated 18ga butt connector would fit into a 12ga ring or not. [you would have to cut it in half to get the right length. in any event, if i have something that will work, or i can whip something up, PM me your address and i'll drop a couple in the mail for ya. gratis.
[Re: cdstl]
#2852538
11/28/20 01:08 PM
11/28/20 01:08 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
Just stick another piece of wire in the terminal along with your 18g.
[Re: moparx]
#2852634
11/28/20 04:41 PM
11/28/20 04:41 PM
Posts: 1,487 STL
cdstl
STL
i have a bunch of 18ga ring terminals for 1/4" and 5/16" bolts. will either of those sizes work ? i haven't looked into whether an uninsulated 18ga butt connector would fit into a 12ga ring or not. [you would have to cut it in half to get the right length. in any event, if i have something that will work, or i can whip something up, PM me your address and i'll drop a couple in the mail for ya. gratis. I'm actually ok with what I have going on. I wasn't sure if the item that I'm talking about even exists, but if they do I'll pick up a few. Thanks for the offer.
[Re: cdstl]
#2852752
11/28/20 10:24 PM
11/28/20 10:24 PM
Posts: 20,171 Park Forest, IL
slantzilla
Park Forest, IL
I just strip extra length and double it up into the lug.
[Re: slantzilla]
#2852809
11/29/20 07:04 AM
11/29/20 07:04 AM
Posts: 5,778 ohio
ruderunner
ohio
This ^ is one option. If you have something else that needs an 18ga ground, put it in the same terminal.
2 18ga equals 1 14ga.
Angry white pureblood male
