caltrac set up #2851307
11/25/20 11:04 AM
11/25/20 11:04 AM
ma.
duspan Offline OP
duspan  Offline OP
ma.
how many of you running a longer (s-10) front half to the mono springs and also the bars in your mopar, and how is it working out? thanks
Re: caltrac set up [Re: duspan] #2851341
11/25/20 12:32 PM
11/25/20 12:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I am and I love it.....
Re: caltrac set up [Re: Thumperdart] #2851358
11/25/20 01:06 PM
11/25/20 01:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mine are the shorter A-body split mono's and no issues here. 1.36 60 ft. on 275's.
Are longer front segments supposed to be better?
'63 Dodge 330
11.19 @ 121 mph
Re: caltrac set up [Re: GY3] #2851449
11/25/20 04:18 PM
11/25/20 04:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Moves the instant center farther forward for starters to transfer weight like right NOW and I've been easy 1.33-1.34's footin to 2200 r's and hope to see lower yet when I put it on slicks and leave wherever it's happiest with the t-ram.....
Re: caltrac set up [Re: Thumperdart] #2851460
11/25/20 04:36 PM
11/25/20 04:36 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Yes the longer front segment moves the IC forward and takes some of the "violence" out of the intial hit. Im not 100% sure about now, but i know Jason Digby was running the A body front segment springs for a long time, and deep into the 4sec range. IT can be done with the shorter segment but will just take a serious shock that has the valving to control that short IC hit. Shorter IC makes it seperate faster so good shock can slow it down/control it. IF starting from scratch get the longer segment, but make sure you get good rear shocks, they are almost more important than the spring
....BAD A$$ STREET CAR.....
Re: caltrac set up [Re: n20mstr] #2851500
11/25/20 06:22 PM
11/25/20 06:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I've been 1.33 on 5-ways and I know that's not stellar or anything but it is a driver and street car first and foremost. Now I have Shiloh's old Vikings on the rear and on QTP's it went a 1.34 footin to 2200 r's but I'm sure on a full slick it would be better and soon I will know for sure. Bottom hole and 1 flat preload is all I've tried in years....
Re: caltrac set up [Re: Thumperdart] #2851951
11/26/20 06:23 PM
11/26/20 06:23 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Stock length leaf Spring.. .. not sure if matters or not shruggy
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: caltrac set up [Re: WHITEDART] #2851952
11/26/20 06:27 PM
11/26/20 06:27 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
My best 60ft to date
Re: caltrac set up [Re: WHITEDART] #2852036
11/27/20 12:00 AM
11/27/20 12:00 AM
Louisiana
Red440 Online content
Red440  Online Content
Louisiana
That small block is humping!!! The caltracs are definitely not an issue, you are very close to a 7 second 1/4 mile ET. Keep digging you are almost there.
Re: caltrac set up [Re: Red440] #2852300
11/27/20 07:00 PM
11/27/20 07:00 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Thanks will keep chipping away at it
