Re: caltrac set up
[Re: Thumperdart]
#2851358
11/25/20 01:06 PM
11/25/20 01:06 PM
Posts: 4,680 Wichita
GY3
Wichita
Mine are the shorter A-body split mono's and no issues here. 1.36 60 ft. on 275's.
Are longer front segments supposed to be better?
Re: caltrac set up
[Re: GY3]
#2851449
11/25/20 04:18 PM
11/25/20 04:18 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Moves the instant center farther forward for starters to transfer weight like right NOW and I've been easy 1.33-1.34's footin to 2200 r's and hope to see lower yet when I put it on slicks and leave wherever it's happiest with the t-ram.....
Re: caltrac set up
[Re: Thumperdart]
#2851460
11/25/20 04:36 PM
11/25/20 04:36 PM
Posts: 4,679 On the parachute mount
n20mstr
Yes the longer front segment moves the IC forward and takes some of the "violence" out of the intial hit. Im not 100% sure about now, but i know Jason Digby was running the A body front segment springs for a long time, and deep into the 4sec range. IT can be done with the shorter segment but will just take a serious shock that has the valving to control that short IC hit. Shorter IC makes it seperate faster so good shock can slow it down/control it. IF starting from scratch get the longer segment, but make sure you get good rear shocks, they are almost more important than the spring
....BAD A$$ STREET CAR.....
Re: caltrac set up
[Re: n20mstr]
#2851500
11/25/20 06:22 PM
11/25/20 06:22 PM
Thumperdart
State of confusion
I've been 1.33 on 5-ways and I know that's not stellar or anything but it is a driver and street car first and foremost. Now I have Shiloh's old Vikings on the rear and on QTP's it went a 1.34 footin to 2200 r's but I'm sure on a full slick it would be better and soon I will know for sure. Bottom hole and 1 flat preload is all I've tried in years....
Re: caltrac set up
[Re: Thumperdart]
#2851951
11/26/20 06:23 PM
11/26/20 06:23 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Stock length leaf Spring.. .. not sure if matters or not
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
