Mallory metal in crank #2850782
11/23/20 11:41 PM
11/23/20 11:41 PM
USA
hudsonhornet7x Offline OP
USA
Any problem with Mallory metal installed radially in the crank counterweight? As in pressed in and welded to the crank counterweight? Thanks for any advice.
Re: Mallory metal in crank [Re: hudsonhornet7x] #2850786
11/23/20 11:59 PM
11/23/20 11:59 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
As vs circumferential, which I believe is the norm? Others can weigh in, as I have never seen it this way that you are describing or the best term that needs to be used to clarify. bump
So look at me, 20K posts boogie
Maybe time to retire, I should start a poll. laugh2
Re: Mallory metal in crank [Re: jcc] #2850790
11/24/20 12:07 AM
11/24/20 12:07 AM
USA
USA
I am doing a poor job of describing the area. Here is a sample pic of where and what I mean. Mallory metal pressed into the hole and then welded shut.
Re: Mallory metal in crank [Re: hudsonhornet7x] #2850794
11/24/20 12:24 AM
11/24/20 12:24 AM
Kirkland, Washington
Pacnorthcuda Offline
That’s a completely common and expected use of Mallory metal.
Re: Mallory metal in crank [Re: hudsonhornet7x] #2850795
11/24/20 12:25 AM
11/24/20 12:25 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I'm no crankshaft expert but would sleep better with the weight added axially rather than radially
Re: Mallory metal in crank [Re: INTMD8] #2850815
11/24/20 03:08 AM
11/24/20 03:08 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
It is fine if it is welded properly. I have seen some "off shore" cranks with the metal pressed in with NO weld. Not sure I would be that brave. As long as the weight is positioned correctly during balancing is should not be anything to worry over.
Todd
Re: Mallory metal in crank [Re: sasquatch] #2850846
11/24/20 09:10 AM
11/24/20 09:10 AM
USA
USA
Thanks all,
Here is a picture of the work done:
Re: Mallory metal in crank [Re: hudsonhornet7x] #2850910
11/24/20 02:01 PM
11/24/20 02:01 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted by Gene Morris
Thanks all,
I like to see the seam disappear..........that wasn't done very well IMO.
Seeing a hint of it is one thing..............seeing a parting line between hole and fill would be concerning.
Re: Mallory metal in crank [Re: tubtar] #2851023
11/24/20 06:07 PM
11/24/20 06:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I would take the one if the first photo over the one in the second photo. I'm a big fan of doing a weld properly and leaving it alone. When I see ground welds the first thing I think is it was done by a poor welder and they're trying to put lipstick on a pig. If that weld had to be ground to sit flush with the surface of the throw, it should at least not have any seam showing. There is only one small spot with evidence of penetration !
Re: Mallory metal in crank [Re: Stanton] #2851250
11/25/20 08:28 AM
11/25/20 08:28 AM
VA
dragon slayer Online content
dragon slayer  Online Content
VA
When I did mine, and this is for a street motor, you are counter sunk, and press fit. Followed by welding in the countersunk area. Important if there is a clearance issue. I do know that the performance shops around here for the racers, will only put them in horizontally.
Re: Mallory metal in crank [Re: dragon slayer] #2851264
11/25/20 08:58 AM
11/25/20 08:58 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I never personally did any of this type of work. Seems like it would be very difficult to get a decent press fit, while still being able to fixture the crank for the press. I could see this getting very time con$uming.
The guy that did the crank in the turbo engine for me used lead backed up by steel slugs tig welded over it. Seemed to do the job. Couldn’t give you a reason that I would suggest against it.
Re: Mallory metal in crank [Re: TRENDZ] #2851523
11/25/20 07:04 PM
11/25/20 07:04 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I had it done once before to a crank that was balanced before it had the counter weights turned down for a low deck engine. They had to fill the hold with Mallory metal to balance it and welded to keep it in place. It lasted a good few years. Then one time at monster Mopar weekend back in 2013 the slug came out and took out #1 piston. I would just make sure it is welded in real good.
Re: Mallory metal in crank [Re: hudsonhornet7x] #2851618
11/25/20 10:40 PM
11/25/20 10:40 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Man thats ugly. Here's the right way
Re: Mallory metal in crank [Re: Hot 340] #2851636
11/25/20 11:59 PM
11/25/20 11:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
One of the Mopars at a fast race in about '04 had it come out, go thru the pan, oil his tires. He scraped the wall. Not worth the risk IMHO.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Mallory metal in crank [Re: TRENDZ] #2851769
11/26/20 11:30 AM
11/26/20 11:30 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Mallory metal (Tungsten alloy) is not magic, it's just heavier than the steel removed to make room for it.
If you have enough room, lead works very well (you have to use more for the same effect) at 10% of the price (material only).
Boffin Emeritus
Re: Mallory metal in crank [Re: polyspheric] #2851796
11/26/20 12:55 PM
11/26/20 12:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have a crank that’s full of lead with strips tig welded over the area. The whole crank has a dull thud when tapped with a hammer but no cracks found (zy glowed and magged) older SS engine crank. If plug comes out it’s the welders fault, must be rosette tig welded.
Re: Mallory metal in crank [Re: cudaman1969] #2851802
11/26/20 01:08 PM
11/26/20 01:08 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Decades ago when RHS was making "crate" motors, I participated in a teardown of one of their 440's. It had been internally balanced to allow use of the heavy rods and the weights were inserted radially and welded exactly as the first photo shows. Just a comment, nothing more.
Re: Mallory metal in crank [Re: 6PakBee] #2851808
11/26/20 01:18 PM
11/26/20 01:18 PM
USA
USA
Thank you all for the replies. At the moment I only have this picture to go on. I will admit I do nothave a warm fuzzy feeling on this.
Re: Mallory metal in crank [Re: hudsonhornet7x] #2851816
11/26/20 01:41 PM
11/26/20 01:41 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Here is 50 shades of ugly, done in 79 by a crankshaft shop, offset ground and balanced to some odd rods and heavy pistons. Makes a 318 block into a 340 with a hair of a cheater stroke.
Its dead straight and all is equal and it likes 7700 rpm.
More ugly then my sister, but it works.
Would I put it in a race block.... ummm probably not, but it does work and has worked.
STOP POTATO HATE!
Re: Mallory metal in crank [Re: Mr PotatoHead] #2851819
11/26/20 01:48 PM
11/26/20 01:48 PM
USA
USA
Wow!!! Well at least it works!!! The crank I posted ( 2nd picture) is/was destined for a supercharged gen III. 800+ horse.
