Re: Mallory metal in crank
[Re: hudsonhornet7x]
#2850786
11/23/20 11:59 PM
11/23/20 11:59 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Any problem with Mallory metal installed radially in the crank counterweight? As in pressed in and welded to the crank counterweight? Thanks for any advice. As vs circumferential, which I believe is the norm? Others can weigh in, as I have never seen it this way that you are describing or the best term that needs to be used to clarify. So look at me, 20K posts Maybe time to retire, I should start a poll.
#2850795
11/24/20 12:25 AM
11/24/20 12:25 AM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I'm no crankshaft expert but would sleep better with the weight added axially rather than radially
#2850910
11/24/20 02:01 PM
11/24/20 02:01 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Thanks all,
Here is a picture of the work done: I like to see the seam disappear..........that wasn't done very well IMO. Seeing a hint of it is one thing..............seeing a parting line between hole and fill would be concerning.
[Re: dragon slayer]
#2851264
11/25/20 08:58 AM
11/25/20 08:58 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I never personally did any of this type of work. Seems like it would be very difficult to get a decent press fit, while still being able to fixture the crank for the press. I could see this getting very time con$uming. The guy that did the crank in the turbo engine for me used lead backed up by steel slugs tig welded over it. Seemed to do the job. Couldn’t give you a reason that I would suggest against it.
[Re: Hot 340]
#2851636
11/25/20 11:59 PM
11/25/20 11:59 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
One of the Mopars at a fast race in about '04 had it come out, go thru the pan, oil his tires. He scraped the wall. Not worth the risk IMHO.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TRENDZ]
#2851769
11/26/20 11:30 AM
11/26/20 11:30 AM
Posts: 4,206 New York
polyspheric
New York
Mallory metal (Tungsten alloy) is not magic, it's just heavier than the steel removed to make room for it. If you have enough room, lead works very well (you have to use more for the same effect) at 10% of the price (material only).
Boffin Emeritus
[Re: cudaman1969]
#2851802
11/26/20 01:08 PM
11/26/20 01:08 PM
Posts: 10,718 North Dakota
6PakBee
North Dakota
Decades ago when RHS was making "crate" motors, I participated in a teardown of one of their 440's. It had been internally balanced to allow use of the heavy rods and the weights were inserted radially and welded exactly as the first photo shows. Just a comment, nothing more.
#2851816
11/26/20 01:41 PM
11/26/20 01:41 PM
Posts: 9,460 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Here is 50 shades of ugly, done in 79 by a crankshaft shop, offset ground and balanced to some odd rods and heavy pistons. Makes a 318 block into a 340 with a hair of a cheater stroke.
Its dead straight and all is equal and it likes 7700 rpm.
More ugly then my sister, but it works.
Would I put it in a race block.... ummm probably not, but it does work and has worked.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2851819
11/26/20 01:48 PM
11/26/20 01:48 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Wow!!! Well at least it works!!! The crank I posted ( 2nd picture) is/was destined for a supercharged gen III. 800+ horse.
