Phoenix Graphics Bumblebee Stripe #2850757
11/23/20 10:41 PM
11/23/20 10:41 PM
South San Francisco, Ca
70sixpkrt Offline OP
I need to order a new Black bumblebee stripe and wondering how good are the Phoenix Graphics stripes for a 70 Charger.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Phoenix Graphics Bumblebee Stripe [Re: 70sixpkrt] #2850907
11/24/20 01:29 PM
11/24/20 01:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used a few of their body strip decals, quality was good, no issues....but what you need to clarify with them sometimes is the stripe sheen/finish, if it's not mentioned before ordering, it will either hold up your order, or you get what they send ...
Mike
Re: Phoenix Graphics Bumblebee Stripe [Re: DAYCLONA] #2850914
11/24/20 02:10 PM
11/24/20 02:10 PM
Mike
For a bumblebee stripe, would it be gloss black?
4-speed
3:54 Dana
Re: Phoenix Graphics Bumblebee Stripe [Re: 70sixpkrt] #2851014
11/24/20 05:42 PM
11/24/20 05:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Most all the black stripes offered over the last few decades from vendors are incorrect in sheen/finish, original black stripes when new had a very slight texture to the surface and a "dull" matte sheen which wore/faded as they aged in the weather/UV, only one company (Motor City Originals) back in the day offered "original" style decals in the correct textured black finish, the mat'l is still available from 3M, if OEM is your choice perhaps you can have Phoenix, or another stripevendor acquire it and cut a decal from it, the correct material is currently marketed under the 3M trade name Di-Noc
Mike
Re: Phoenix Graphics Bumblebee Stripe [Re: DAYCLONA] #2851029
11/24/20 06:24 PM
11/24/20 06:24 PM
Thank you up
4-speed
3:54 Dana
Re: Phoenix Graphics Bumblebee Stripe [Re: DAYCLONA] #2851265
11/25/20 08:59 AM
11/25/20 08:59 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Mike
Mike
Mike - True statements and Di-noc is still made today, unfortunately I don’t believe the original texture is offered. Di-noc is a generic name for a vinyl wrap, offered in many textures and patterns. I did an exhaustive search for this when making my AAR stripes, those originally had a pattern best described as an orange peel. Unsure if the material was any different for other models using a low sheen black. Seems like the base material would have been similar. I wasn’t able to find a match offered or a leftover roll for sale. The common belief is that the original material required chemicals that are no longer considered acceptable for use today and therefor not offered in its original form.
If the OP desires, and has a material they feel is closer in texture/sheen, I’m almost certain PHX Graphics would work with him to cut the material, though I’d recommend coordinating prior to purchasing material.
Best of luck finding what’s correct, it can be a lesson in frustration.
Re: Phoenix Graphics Bumblebee Stripe [Re: AAR#2] #2851294
11/25/20 10:28 AM
11/25/20 10:28 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Just as an aside, Di-Noc Chemical Arts was a local Cleveland company back in the 50s and 60s.
I lived just a 1/2 mile from them in the Collinwood area of Cleveland.
I don't know what they produced there, but the plant exuded a pungent odor
that we all called "banana oil".
They may have been involved in the production of appliques???
Joe
P.S. After looking them up, it seems as 3M either bought them or use their name.
Re: Phoenix Graphics Bumblebee Stripe [Re: AAR#2] #2851388
11/25/20 01:38 PM
11/25/20 01:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Mike
The Di-Noc line has been expanded greatly the last 10 years or so covering wraps, carbon fiber wraps and adhesive sheeting, along with an architectural line of wraps and adhesive sheeting, granted you won't match the "orange peel" (good call!) texture of OEM stripes, but the Di-Noc lines have some very interesting pattern/finishes that can be applied to our automotive applications resulting in a much more OEM complimentary look....I recently purchased some 3M Di-Noc rolls in their Architectural line for a customer's project, very impressive mat'l.....I'm currently looking at making a set of T/A stripes in their "pebble" textured mat'l to see how close they match OEM
Mike
Re: Phoenix Graphics Bumblebee Stripe [Re: DAYCLONA] #2851397
11/25/20 02:04 PM
11/25/20 02:04 PM
MA
steve70 Offline
steve70  Offline
MA
Here are a couple pictures of the texture on an original T/A's stripes
1970 Challenger T/A 4 speed
Re: Phoenix Graphics Bumblebee Stripe [Re: steve70] #2851416
11/25/20 02:50 PM
11/25/20 02:50 PM
Wow. Thanks for the info. I did not know it was somewhat of a textured pattern. My car came original with the Longitudinal Stripe but I think it would be too much yellow.
4-speed
3:54 Dana
Re: Phoenix Graphics Bumblebee Stripe [Re: 70sixpkrt] #2851431
11/25/20 03:35 PM
11/25/20 03:35 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Here’s an example from my original AAR stripe, basically the same as the T/A stripe. The example posted above appears just a little more course but within what I’d call lot variations
Re: Phoenix Graphics Bumblebee Stripe [Re: AAR#2] #2851436
11/25/20 03:55 PM
11/25/20 03:55 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Also worth mentioning is that unless you were to be looking for the texture, as in up on top of it, and have the correct lighting/reflecting, you would never notice it. This is why so many folks are so surprised that there is a texture at all.
Re: Phoenix Graphics Bumblebee Stripe [Re: AAR#2] #2851505
11/25/20 06:34 PM
11/25/20 06:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW there's a set of Cuda hockey stripes on FB from Phoenix Graphix, and the photos show the texture.
Re: Phoenix Graphics Bumblebee Stripe [Re: topside] #2851583
11/25/20 09:24 PM
11/25/20 09:24 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Screen image or link???
Re: Phoenix Graphics Bumblebee Stripe [Re: AAR#2] #2851610
11/25/20 10:14 PM
11/25/20 10:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
On "Classic Mopars BUY.SELL.TRADE"
Re: Phoenix Graphics Bumblebee Stripe [Re: topside] #2851615
11/25/20 10:32 PM
11/25/20 10:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Interesting....but it appears on my screen that the "texture" goes beyond the actual decal, I'm assuming that's the decal face binder that's textured not the decal?....
Mike
Re: Phoenix Graphics Bumblebee Stripe [Re: DAYCLONA] #2851637
11/26/20 12:01 AM
11/26/20 12:01 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Don’t be fooled, what you believe is decal texture is actually the transfer film over the top, once removed you will not have what you think.
Re: Phoenix Graphics Bumblebee Stripe [Re: AAR#2] #2851792
11/26/20 12:50 PM
11/26/20 12:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That does appear to be the case, dang it.
