Re: Phoenix Graphics Bumblebee Stripe
[Re: DAYCLONA]
#2850914
11/24/20 02:10 PM
11/24/20 02:10 PM
Posts: 3,680 South San Francisco, Ca
70sixpkrt
I've used a few of their body strip decals, quality was good, no issues....but what you need to clarify with them sometimes is the stripe sheen/finish, if it's not mentioned before ordering, it will either hold up your order, or you get what they send ...
Mike For a bumblebee stripe, would it be gloss black?
[Re: 70sixpkrt]
#2851014
11/24/20 05:42 PM
11/24/20 05:42 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike For a bumblebee stripe, would it be gloss black? Most all the black stripes offered over the last few decades from vendors are incorrect in sheen/finish, original black stripes when new had a very slight texture to the surface and a "dull" matte sheen which wore/faded as they aged in the weather/UV, only one company (Motor City Originals) back in the day offered "original" style decals in the correct textured black finish, the mat'l is still available from 3M, if OEM is your choice perhaps you can have Phoenix, or another stripevendor acquire it and cut a decal from it, the correct material is currently marketed under the 3M trade name Di-Noc Mike
[Re: DAYCLONA]
#2851265
11/25/20 08:59 AM
11/25/20 08:59 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Mike For a bumblebee stripe, would it be gloss black? Most all the black stripes offered over the last few decades from vendors are incorrect in sheen/finish, original black stripes when new had a very slight texture to the surface and a "dull" matte sheen which wore/faded as they aged in the weather/UV, only one company (Motor City Originals) back in the day offered "original" style decals in the correct textured black finish, the mat'l is still available from 3M, if OEM is your choice perhaps you can have Phoenix, or another stripevendor acquire it and cut a decal from it, the correct material is currently marketed under the 3M trade name Di-Noc Mike Mike - True statements and Di-noc is still made today, unfortunately I don’t believe the original texture is offered. Di-noc is a generic name for a vinyl wrap, offered in many textures and patterns. I did an exhaustive search for this when making my AAR stripes, those originally had a pattern best described as an orange peel. Unsure if the material was any different for other models using a low sheen black. Seems like the base material would have been similar. I wasn’t able to find a match offered or a leftover roll for sale. The common belief is that the original material required chemicals that are no longer considered acceptable for use today and therefor not offered in its original form. If the OP desires, and has a material they feel is closer in texture/sheen, I’m almost certain PHX Graphics would work with him to cut the material, though I’d recommend coordinating prior to purchasing material. Best of luck finding what’s correct, it can be a lesson in frustration.
[Re: AAR#2]
#2851294
11/25/20 10:28 AM
11/25/20 10:28 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Just as an aside, Di-Noc Chemical Arts was a local Cleveland company back in the 50s and 60s. I lived just a 1/2 mile from them in the Collinwood area of Cleveland.
I don't know what they produced there, but the plant exuded a pungent odor that we all called "banana oil".
They may have been involved in the production of appliques???
Joe
P.S. After looking them up, it seems as 3M either bought them or use their name.
[Re: AAR#2]
#2851388
11/25/20 01:38 PM
11/25/20 01:38 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike For a bumblebee stripe, would it be gloss black? Most all the black stripes offered over the last few decades from vendors are incorrect in sheen/finish, original black stripes when new had a very slight texture to the surface and a "dull" matte sheen which wore/faded as they aged in the weather/UV, only one company (Motor City Originals) back in the day offered "original" style decals in the correct textured black finish, the mat'l is still available from 3M, if OEM is your choice perhaps you can have Phoenix, or another stripevendor acquire it and cut a decal from it, the correct material is currently marketed under the 3M trade name Di-Noc Mike Mike - True statements and Di-noc is still made today, unfortunately I don’t believe the original texture is offered. Di-noc is a generic name for a vinyl wrap, offered in many textures and patterns. I did an exhaustive search for this when making my AAR stripes, those originally had a pattern best described as an orange peel. Unsure if the material was any different for other models using a low sheen black. Seems like the base material would have been similar. I wasn’t able to find a match offered or a leftover roll for sale. The common belief is that the original material required chemicals that are no longer considered acceptable for use today and therefor not offered in its original form. If the OP desires, and has a material they feel is closer in texture/sheen, I’m almost certain PHX Graphics would work with him to cut the material, though I’d recommend coordinating prior to purchasing material. Best of luck finding what’s correct, it can be a lesson in frustration. The Di-Noc line has been expanded greatly the last 10 years or so covering wraps, carbon fiber wraps and adhesive sheeting, along with an architectural line of wraps and adhesive sheeting, granted you won't match the "orange peel" (good call!) texture of OEM stripes, but the Di-Noc lines have some very interesting pattern/finishes that can be applied to our automotive applications resulting in a much more OEM complimentary look....I recently purchased some 3M Di-Noc rolls in their Architectural line for a customer's project, very impressive mat'l.....I'm currently looking at making a set of T/A stripes in their "pebble" textured mat'l to see how close they match OEM Mike
[Re: DAYCLONA]
#2851397
11/25/20 02:04 PM
11/25/20 02:04 PM
Posts: 892 MA
steve70
MA
Here are a couple pictures of the texture on an original T/A's stripes
1970 Challenger T/A 4 speed
[Re: topside]
#2851583
11/25/20 09:24 PM
11/25/20 09:24 PM
AAR#2
Dry Heat AZ
FWIW there's a set of Cuda hockey stripes on FB from Phoenix Graphix, and the photos show the texture. Screen image or link???
[Re: topside]
#2851615
11/25/20 10:32 PM
11/25/20 10:32 PM
Posts: 18,157 Mass
DAYCLONA
Mass
On "Classic Mopars BUY.SELL.TRADE"
Interesting....but it appears on my screen that the "texture" goes beyond the actual decal, I'm assuming that's the decal face binder that's textured not the decal?.... Mike
