Re: 73 roadrunner 318 trans rooster comb
[Re: stumpy]
#2848107
11/18/20 12:51 PM
11/18/20 12:51 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Have you tried adjusting the shift linkage. It can be sensitive to position. I would start here like he said. I have never seen a rooster comb wear out. Not saying it won't but I haven't seen one. Check all the linkage bushings, then have somebody move the shifter to all the positions while you are under it looking at it. It is not uncommon to have a transmission line or busted mount cause the shift linkage to hit and not engage park fully.
[Re: stumpy]
#2848115
11/18/20 01:07 PM
11/18/20 01:07 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
Have you tried adjusting the shift linkage. It can be sensitive to position. X2, I bet it's just a linkage adjustment issue . . . or maybe the neutral safety switch might need to be looked at . . . OP stated it won't start in Park sometimes . . . As an aside . . . I used 72 or 73 (can't recall the year) exhaust manifolds on my 70 Sport Satellite - they have the larger openings to match exhaust port on 340/360 heads, but still look like 318 manifolds !! Even stamped 318 - RR !!! . . . the right side didn't even have the provision for heat riser drilled !!
[Re: dvw]
#2848120
11/18/20 01:13 PM
11/18/20 01:13 PM
IMGTX
The late model roosters have plastic on them that can break. Doug This I did not know. Learned me something new. But I rarely work on any Mopar RWD transmissions newer than 74.
[Re: IMGTX]
#2848131
11/18/20 01:22 PM
11/18/20 01:22 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The plastic shoe only affects the back-up light operation, NSS is the metal part of the rooster comb.
As stated, probably a linkage problem; look for missing/sloppy plastic bushings. While holding the key in START, slam the shift handle hard against Park.
[Re: John_Kunkel]
#2848173
11/18/20 02:42 PM
11/18/20 02:42 PM
Posts: 19,355 north of coder
moparx
i agree with what john states above. however, one time i stumbled into a situation where the plastic started to deform and a tiny tab had folded over one of the metal tabs and stuck there. i can't remember whether it was the park or neutral one. i just whittled it away with my pocket knife and that was that. i would start with checking the linkage adjustment and look close at the bushings for slop. please keep us updated.
