73 roadrunner 318 trans rooster comb #2847995
11/18/20 09:00 AM
11/18/20 09:00 AM
Poland, Ohio 44514
captainjack Offline OP
Poland, Ohio 44514
I have a 73 Plymouth Roadrunner 318. It doesn't want to start in park all the time. Have to put it in neutral. I was told to replace the rooster comb. Where do I find one to replaace it. PM or call Jack at 330-719-0606 or e mail at moparjack67@sbcglobal.net. THANKS! Thanks for the add moparts!
Re: 73 roadrunner 318 trans rooster comb [Re: captainjack] #2848000
11/18/20 09:23 AM
11/18/20 09:23 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That is part of the valve body. Any shop that has parts transmission should have one. You may have to buy the entire valve body . I’m not sure if a 727 one will fit on a 904 body. It may just be the switch. I’d change that first. It’s on the outside. I had one loose on a 518 and I took it out and tack welded it with my mig.
Re: 73 roadrunner 318 trans rooster comb [Re: captainjack] #2848005
11/18/20 09:39 AM
11/18/20 09:39 AM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
Post a pic of the car please
Re: 73 roadrunner 318 trans rooster comb [Re: WS68SSC] #2848092
11/18/20 12:34 PM
11/18/20 12:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried adjusting the shift linkage. It can be sensitive to position.
Re: 73 roadrunner 318 trans rooster comb [Re: stumpy] #2848107
11/18/20 12:51 PM
11/18/20 12:51 PM
IMGTX Offline
IMGTX  Offline
I would start here like he said.
I have never seen a rooster comb wear out. Not saying it won't but I haven't seen one.
Check all the linkage bushings, then have somebody move the shifter to all the positions while you are under it looking at it. It is not uncommon to have a transmission line or busted mount cause the shift linkage to hit and not engage park fully.
Re: 73 roadrunner 318 trans rooster comb [Re: stumpy] #2848115
11/18/20 01:07 PM
11/18/20 01:07 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
X2, I bet it's just a linkage adjustment issue . . . or maybe the neutral safety switch might need to be looked at . . . OP stated it won't start in Park sometimes . . .
As an aside . . . I used 72 or 73 (can't recall the year) exhaust manifolds on my 70 Sport Satellite - they have the larger openings to match exhaust port on 340/360 heads, but still look like 318 manifolds !! Even stamped 318 - RR !!! . . . the right side didn't even have the provision for heat riser drilled !!
Re: 73 roadrunner 318 trans rooster comb [Re: a12rag] #2848117
11/18/20 01:11 PM
11/18/20 01:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The late model roosters have plastic on them that can break. Pull the pan and look. Available on Ebay $10.99 . Look up 727 rooster comb. 904/727 are the same.
Doug
Re: 73 roadrunner 318 trans rooster comb [Re: dvw] #2848120
11/18/20 01:13 PM
11/18/20 01:13 PM
IMGTX Offline
IMGTX  Offline
Doug
This I did not know. Learned me something new. up
But I rarely work on any Mopar RWD transmissions newer than 74.
Re: 73 roadrunner 318 trans rooster comb [Re: IMGTX] #2848131
11/18/20 01:22 PM
11/18/20 01:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The plastic shoe only affects the back-up light operation, NSS is the metal part of the rooster comb.
As stated, probably a linkage problem; look for missing/sloppy plastic bushings. While holding the key in START, slam the shift handle hard against Park.
Re: 73 roadrunner 318 trans rooster comb [Re: John_Kunkel] #2848173
11/18/20 02:42 PM
11/18/20 02:42 PM
moparx Online content
moparx  Online Content
i agree with what john states above.
however, one time i stumbled into a situation where the plastic started to deform and a tiny tab had folded over one of the metal tabs and stuck there. i can't remember whether it was the park or neutral one. i just whittled it away with my pocket knife and that was that.
i would start with checking the linkage adjustment and look close at the bushings for slop.
please keep us updated.
beer
