440 Source flow numbers #2847489
11/17/20 11:39 AM
11/17/20 11:39 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
We had a discussion a while back about these heads. At $1000 for the pair, they are a pretty decent alternative. I would say that they deserve a trip to a machinist for a valve job, to increase flow, and to check for whatever else. My set had 2 valve spring seats under one of the springs.
The numbers are as delivered on the top line, the bottom row represents a valve job to open up the seats and center the valves. I don’t remember any numbers on how wide the as delivered seats were or what they are now.
FWIW, here you go...
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 440 Source flow numbers [Re: cdstl] #2847526
11/17/20 12:30 PM
11/17/20 12:30 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
So what does a machine shop charge to inspect a brand new set of heads? My local shop charges $500 to rebuild a set of factory heads.(new guides, grind valves/seats and surface head) If a shop is going to charge that, your $1000 set of heads turns into a $1500 set.
Re: 440 Source flow numbers [Re: burdar] #2847553
11/17/20 12:55 PM
11/17/20 12:55 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Originally Posted by burdar
Quote
.....Which is still a good deal for aluminum heads that are truly ready to go
Re: 440 Source flow numbers [Re: moparjim79] #2847683
11/17/20 04:00 PM
11/17/20 04:00 PM
Quote
Me thinks the Eddy 75.0 CC chamber RPM head is a better deal at $1500.00 a set from Summit than having to have the 440 source heads tricked out to flow almost as much as the Eddy do out of the box work scope
Re: 440 Source flow numbers [Re: cdstl] #2847716
11/17/20 04:42 PM
11/17/20 04:42 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
Good info, thanks.
1972 Road Runner
1988 Shelby CSX-T
Re: 440 Source flow numbers [Re: racerx20] #2847743
11/17/20 05:49 PM
11/17/20 05:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
Most everyone says the Edelbrocks need to be checked over by a machine shop too. work shruggy
Re: 440 Source flow numbers [Re: burdar] #2847773
11/17/20 06:54 PM
11/17/20 06:54 PM
BDW Offline
BDW  Offline
Curious about cost too, intake picked up ~8% flow improvement.
Exhaust looks like no improvement, so is the juice worth the squeeze?
Re: 440 Source flow numbers [Re: BDW] #2847792
11/17/20 07:21 PM
11/17/20 07:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think you're all missing the point of a 440Source head ... they are made to be a direct replacement for a standard cast iron head. So compare apples to apples. As they come from 440Source is probably as good as any iron head out of the factory. If you're going to have heads checked, machined, ported, polished, blueprinted and flowed then you probably shouldn't be starting with 440Source heads !!
Re: 440 Source flow numbers [Re: Stanton] #2847821
11/17/20 08:23 PM
11/17/20 08:23 PM
Kirkland, Washington
Pacnorthcuda Offline
Unless factory appearance is important! If it is, the 440source are the way to go. If you clean them up even better.
Re: 440 Source flow numbers [Re: Stanton] #2847875
11/17/20 10:34 PM
11/17/20 10:34 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Disagree, dollar for dollar the 440 source heads win just because of the weight first and foremost. Then ease of porting. And deck mill. But if you just slap em on, still 9/10 better than a factory iron head
Re: 440 Source flow numbers [Re: burdar] #2847914
11/17/20 11:50 PM
11/17/20 11:50 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Quote
My machinist only charged me $75 per head for the valve job, remember that he is doing an entire build for me. I picked these heads because I'm trying to keep a factory car looking factory but I wanted to pick up some power. And don't forget that the factory heads that were on the car didn't have hardened seats either.
If I have another similar car to redo, then I'll use these heads once again. For a performance build, it'll be something else.
This was just an informational post.
Re: 440 Source flow numbers [Re: burdar] #2847958
11/18/20 04:17 AM
11/18/20 04:17 AM
Have you owned and use them? I have with no problems on the 84 CC version of the RPM heads, same on a set of eddy Victor M.W. heads shruggy
Re: 440 Source flow numbers [Re: Cab_Burge] #2848080
11/18/20 12:12 PM
11/18/20 12:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had both Eddys & Stealths on a couple of RBs.
No big problems with either, though both required a little work on valve job & guides.
I also changed springs on both to a double style.
I like the Stealths for their stock-ish look; the old street-racer sneaky thing dies hard grin .
Wasn't going for max power on either, but was happy with the results.
Re: 440 Source flow numbers [Re: BDW] #2848410
11/18/20 11:24 PM
11/18/20 11:24 PM
Washington
madscientist Offline
Washington
Flow numbers are about meaningless on the exhaust side.
Re: 440 Source flow numbers [Re: madscientist] #2848488
11/19/20 08:25 AM
11/19/20 08:25 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I bought a set of 440 stealth heads around 2009/2010. Changed the valve locks from 7 deg to 10 deg since I was running a .533 cam. Ran them for 5-6 years before finally freshening the motor. Had 2 broken inner springs, so put new valve springs on them and had a local guy hand port them. After freshening the bottom end (new rings + bearings), the port job, shaved the heads just a smidgen to clean up the surface I picked up whooping .05 in the 1/4. To me they are the best bang for buck for a head at $1000 a pair. If you want a more serious head, spend the coin on some Trick Flows. I spent $1000 for the 440 source + $500 just for the port job. So I have $1500 into the heads now. I bought a set of Trick Flow 240 and bolted them on a different shortblock, but very similar specs and picked up a good 3 tenths in the 1/4. I also went from 2" headers to 1 3/4" with the trick flows which I think was a mistake. I'm putting the 2" back on for 2021 to see if it picks up even more.
Re: 440 Source flow numbers [Re: cdstl] #2848527
11/19/20 10:16 AM
11/19/20 10:16 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I also forgot to mention that I had the small valve 516 heads on this motor so my flow probably picked up more than a newer head.
I'd do it again.
Re: 440 Source flow numbers [Re: madscientist] #2848899
11/20/20 03:18 AM
11/20/20 03:18 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Do you think that because few seem to test them flowing in the right direction?
Re: 440 Source flow numbers [Re: burdar] #2849051
11/20/20 01:04 PM
11/20/20 01:04 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Quote
They ALL need to be checked and corrected no matter who builds them. Trust me, Edelbrock heads aren't ready to go out of the box either.
Kevin
Re: 440 Source flow numbers [Re: Cab_Burge] #2852470
11/28/20 09:59 AM
11/28/20 09:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The back-to-back flow tests I saw back in the day when the source heads came out showed the Eddy RPM heads OOTB had about 10cfm more on the intake at .600 lift. In OP's case dollar for dollar it's looks like he's ahead with 1500 into his source heads vs 1500 for OOTB eddys, minus the chamber volume differences of course.
