440 Source flow numbers
#2847489
11/17/20 11:39 AM
11/17/20 11:39 AM
Posts: 1,486 STL
cdstl
STL
We had a discussion a while back about these heads. At $1000 for the pair, they are a pretty decent alternative. I would say that they deserve a trip to a machinist for a valve job, to increase flow, and to check for whatever else. My set had 2 valve spring seats under one of the springs.
The numbers are as delivered on the top line, the bottom row represents a valve job to open up the seats and center the valves. I don’t remember any numbers on how wide the as delivered seats were or what they are now.
FWIW, here you go...
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 440 Source flow numbers
[Re: cdstl]
#2847526
11/17/20 12:30 PM
11/17/20 12:30 PM
Posts: 7,358 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I would say that they deserve a trip to a machinist for a valve job, to increase flow, and to check for whatever else. My set had 2 valve spring seats under one of the springs. So what does a machine shop charge to inspect a brand new set of heads? My local shop charges $500 to rebuild a set of factory heads.(new guides, grind valves/seats and surface head) If a shop is going to charge that, your $1000 set of heads turns into a $1500 set.
[Re: burdar]
#2847553
11/17/20 12:55 PM
11/17/20 12:55 PM
Posts: 1,395 Central Pa
moparjim79
Central Pa
I would say that they deserve a trip to a machinist for a valve job, to increase flow, and to check for whatever else. My set had 2 valve spring seats under one of the springs. So what does a machine shop charge to inspect a brand new set of heads? My local shop charges $500 to rebuild a set of factory heads.(new guides, grind valves/seats and surface head) If a shop is going to charge that, your $1000 set of heads turns into a $1500 set. .....Which is still a good deal for aluminum heads that are truly ready to go
[Re: moparjim79]
#2847683
11/17/20 04:00 PM
11/17/20 04:00 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I would say that they deserve a trip to a machinist for a valve job, to increase flow, and to check for whatever else. My set had 2 valve spring seats under one of the springs. So what does a machine shop charge to inspect a brand new set of heads? My local shop charges $500 to rebuild a set of factory heads.(new guides, grind valves/seats and surface head) If a shop is going to charge that, your $1000 set of heads turns into a $1500 set. .....Which is still a good deal for aluminum heads that are truly ready to go Me thinks the Eddy 75.0 CC chamber RPM head is a better deal at $1500.00 a set from Summit than having to have the 440 source heads tricked out to flow almost as much as the Eddy do out of the box
[Re: burdar]
#2847773
11/17/20 06:54 PM
11/17/20 06:54 PM
Posts: 4,679 Florida
BDW
Curious about cost too, intake picked up ~8% flow improvement. Exhaust looks like no improvement, so is the juice worth the squeeze?
[Re: Stanton]
#2847821
11/17/20 08:23 PM
11/17/20 08:23 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
I think you're all missing the point of a 440Source head ... they are made to be a direct replacement for a standard cast iron head. So compare apples to apples. As they come from 440Source is probably as good as any iron head out of the factory. If you're going to have heads checked, machined, ported, polished, blueprinted and flowed then you probably shouldn't be starting with 440Source heads !! Unless factory appearance is important! If it is, the 440source are the way to go. If you clean them up even better.
[Re: Stanton]
#2847875
11/17/20 10:34 PM
11/17/20 10:34 PM
moparjim79
Central Pa
I think you're all missing the point of a 440Source head ... they are made to be a direct replacement for a standard cast iron head. So compare apples to apples. As they come from 440Source is probably as good as any iron head out of the factory. If you're going to have heads checked, machined, ported, polished, blueprinted and flowed then you probably shouldn't be starting with 440Source heads !! Disagree, dollar for dollar the 440 source heads win just because of the weight first and foremost. Then ease of porting. And deck mill. But if you just slap em on, still 9/10 better than a factory iron head
[Re: burdar]
#2847914
11/17/20 11:50 PM
11/17/20 11:50 PM
Posts: 1,486 STL
cdstl
STL
I would say that they deserve a trip to a machinist for a valve job, to increase flow, and to check for whatever else. My set had 2 valve spring seats under one of the springs. So what does a machine shop charge to inspect a brand new set of heads? My local shop charges $500 to rebuild a set of factory heads.(new guides, grind valves/seats and surface head) If a shop is going to charge that, your $1000 set of heads turns into a $1500 set. My machinist only charged me $75 per head for the valve job, remember that he is doing an entire build for me. I picked these heads because I'm trying to keep a factory car looking factory but I wanted to pick up some power. And don't forget that the factory heads that were on the car didn't have hardened seats either. If I have another similar car to redo, then I'll use these heads once again. For a performance build, it'll be something else. This was just an informational post.
[Re: Cab_Burge]
#2848080
11/18/20 12:12 PM
11/18/20 12:12 PM
Posts: 20,642 So Near, Yet So Far
topside
So Near, Yet So Far
I've had both Eddys & Stealths on a couple of RBs. No big problems with either, though both required a little work on valve job & guides. I also changed springs on both to a double style. I like the Stealths for their stock-ish look; the old street-racer sneaky thing dies hard . Wasn't going for max power on either, but was happy with the results.
[Re: BDW]
#2848410
11/18/20 11:24 PM
11/18/20 11:24 PM
Posts: 4,457 Washington
madscientist
Washington
Curious about cost too, intake picked up ~8% flow improvement. Exhaust looks like no improvement, so is the juice worth the squeeze? Flow numbers are about meaningless on the exhaust side.
[Re: cdstl]
#2848527
11/19/20 10:16 AM
11/19/20 10:16 AM
Posts: 1,486 STL
cdstl
STL
I also forgot to mention that I had the small valve 516 heads on this motor so my flow probably picked up more than a newer head.
I'd do it again.
[Re: madscientist]
#2848899
11/20/20 03:18 AM
11/20/20 03:18 AM
Posts: 234 Brisvegas, Australia
Alchemi
Curious about cost too, intake picked up ~8% flow improvement. Exhaust looks like no improvement, so is the juice worth the squeeze? Flow numbers are about meaningless on the exhaust side. Do you think that because few seem to test them flowing in the right direction?
[Re: burdar]
#2849051
11/20/20 01:04 PM
11/20/20 01:04 PM
Posts: 6,545 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Me thinks the Eddy 75.0 CC chamber RPM head is a better deal at $1500.00 a set from Summit than having to have the 440 source heads tricked out to flow almost as much as the Eddy do out of the box Most everyone says the Edelbrocks need to be checked over by a machine shop too. They ALL need to be checked and corrected no matter who builds them. Trust me, Edelbrock heads aren't ready to go out of the box either. Kevin
