Re: Poly 318 intake gaskets?
[Re: Sniper]
#2843889
11/09/20 10:16 AM
11/09/20 10:16 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Never heard of them, but will keep them in mind...Thanks! Mike
[Re: earlymopar]
#2843890
11/09/20 10:22 AM
11/09/20 10:22 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Any of the composite gaskets would be fine for your aluminum intake (if you can locate them). Do not use steel. Those are meant for cast iron intakes. I bought several NOS Offenhauser Poly intake gaskets from a seller on Ebay who seems to be a regular seller. I suggest you keep checking there. Thanks!...yep aware the steel gaskets are for cast iron intakes, there's one cottage mfg making composites with a steel core, not to sure what to make on them, they come in at .050 thick with a silicone print-o-seal, I've scanned Ebay but no luck so far.... would prefer mfg recommended gaskets Mike
[Re: calrobb2000]
#2844302
11/09/20 11:09 PM
11/09/20 11:09 PM
Posts: 18,157 Mass
DAYCLONA
Mass
hi
steel just for cast iron ????
most all 361 383 413 426w 440 use a steel shim valley pan gasket iron or alu intakes !
i have use many on the b rb motors with no prob .
more important is the fit between heads and block for good seal !
Agreed, however the subject is a 1961 318 Poly, very much like a smblk LA (67- up) mopar, just front/rear seals and runner gaskets, no valley pan/gasket Mike
[Re: moparx]
#2844498
11/10/20 01:19 PM
11/10/20 01:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Bruce Toth wrote a bunch of poly articles for chrysler power magazine dealing with intakes and heads. maybe give him a call ? Toth Performance : 724-290-2497 Moparx, I've got the info on Toth's gasket offerings, will probably lean that way, just exploring any other avenues/options/preferred choices that might be available? Thanks Mike
[Re: DAYCLONA]
#2844502
11/10/20 01:27 PM
11/10/20 01:27 PM
Posts: 19,396 north of coder
moparx
sure Mike. i didn't know if you knew about Toth or not. i don't know much about poly's other than the ones i have had over the years. that just amounts to some ran great, while others were junk.
