Poly 318 intake gaskets? #2843590
11/08/20 06:47 PM
11/08/20 06:47 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Looking for suggestions, stock/original 1961 Poly 318, Weiand 7501 aluminum 4 bbl intake install....I see a few current offerings from the cottage aftermarket for intake gaskets, composite, steel, steel core composite, hoping someone has some recommendations for a good supplier/quality gaskets that actually fit/work without issues using an aftermarket aluminum intake...TIA
Mike
Re: Poly 318 intake gaskets? [Re: DAYCLONA] #2843806
11/09/20 08:32 AM
11/09/20 08:32 AM
E
earlymopar Offline
earlymopar  Offline
E
Any of the composite gaskets would be fine for your aluminum intake (if you can locate them). Do not use steel. Those are meant for cast iron intakes. I bought several NOS Offenhauser Poly intake gaskets from a seller on Ebay who seems to be a regular seller. I suggest you keep checking there.
Re: Poly 318 intake gaskets? [Re: earlymopar] #2843814
11/09/20 08:47 AM
11/09/20 08:47 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
never used their poly stuff but the flathead stuff us nice
https://bestgasket.com/vintage-engine-gaskets/
Re: Poly 318 intake gaskets? [Re: Sniper] #2843889
11/09/20 10:16 AM
11/09/20 10:16 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Never heard of them, but will keep them in mind...Thanks!
Mike
Re: Poly 318 intake gaskets? [Re: earlymopar] #2843890
11/09/20 10:22 AM
11/09/20 10:22 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks!...yep aware the steel gaskets are for cast iron intakes, there's one cottage mfg making composites with a steel core, not to sure what to make on them, they come in at .050 thick with a silicone print-o-seal, I've scanned Ebay but no luck so far.... would prefer mfg recommended gaskets
Mike
Re: Poly 318 intake gaskets? [Re: DAYCLONA] #2844195
11/09/20 06:56 PM
11/09/20 06:56 PM
E
earlymopar Offline
earlymopar  Offline
E
Would like to see what these are Mike when and if you find more detail.
Re: Poly 318 intake gaskets? [Re: DAYCLONA] #2844284
11/09/20 10:08 PM
11/09/20 10:08 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
steel just for cast iron ????
most all 361 383 413 426w 440 use a steel shim valley pan gasket iron or alu intakes !
i have use many on the b rb motors with no prob .
more important is the fit between heads and block for good seal !
Re: Poly 318 intake gaskets? [Re: calrobb2000] #2844302
11/09/20 11:09 PM
11/09/20 11:09 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Originally Posted by calrobb2000
hi
Agreed, however the subject is a 1961 318 Poly, very much like a smblk LA (67- up) mopar, just front/rear seals and runner gaskets, no valley pan/gasket
Mike
Re: Poly 318 intake gaskets? [Re: DAYCLONA] #2844487
11/10/20 12:54 PM
11/10/20 12:54 PM
moparx Offline
moparx  Offline
Bruce Toth wrote a bunch of poly articles for chrysler power magazine dealing with intakes and heads. maybe give him a call ?
Toth Performance : 724-290-2497
beer
Re: Poly 318 intake gaskets? [Re: moparx] #2844498
11/10/20 01:19 PM
11/10/20 01:19 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
beer
Moparx, I've got the info on Toth's gasket offerings, will probably lean that way, just exploring any other avenues/options/preferred choices that might be available?
Mike
Re: Poly 318 intake gaskets? [Re: DAYCLONA] #2844502
11/10/20 01:27 PM
11/10/20 01:27 PM
moparx Offline
moparx  Offline
sure Mike. up
i didn't know if you knew about Toth or not.
i don't know much about poly's other than the ones i have had over the years.
that just amounts to some ran great, while others were junk.
beer
