Looking for suggestions, stock/original 1961 Poly 318, Weiand 7501 aluminum 4 bbl intake install....I see a few current offerings from the cottage aftermarket for intake gaskets, composite, steel, steel core composite, hoping someone has some recommendations for a good supplier/quality gaskets that actually fit/work without issues using an aftermarket aluminum intake...TIA
Mike
