Re: Trick Flow Sml Blk Heads
[Re: outcast]
#2842054
11/05/20 09:14 AM
11/05/20 09:14 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
what do they have that well work on this engine.. Thanks Both the 360-1 and 360-2 heads Indy makes will make more power than the Trick Flows. Just go to Indy’s site and read up on them
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: outcast]
#2842298
11/05/20 09:03 PM
11/05/20 09:03 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
what do they have that well work on this engine.. Thanks I have ported 360-1's on my 434, not the best numbers I've seen by far but it runs decent. Street/strip 69 Dart, pump 93, 6.25 @ 110 on pump 93 at 3350#. I wouldn't anything less on 440".
