Trick Flow Sml Blk Heads #2841689
11/04/20 01:40 PM
11/04/20 01:40 PM
HellsGate
outcast Offline OP
outcast  Offline OP
HellsGate
Looking for lnfo to see if anybody is using them and how they work... Going on a 440 cid roller in a 2200 lb car Thanks for any and all info.. Stay safe out there
Re: Trick Flow Sml Blk Heads [Re: outcast] #2841693
11/04/20 01:49 PM
11/04/20 01:49 PM
AndyF Offline
AndyF  Offline
We did one engine with them and they worked okay. Nothing fantastic but they worked fine out of the box. Seemed to be a high quality part. Probably the best choice on the market for a big street SB engine.
Re: Trick Flow Sml Blk Heads [Re: AndyF] #2841778
11/04/20 05:07 PM
11/04/20 05:07 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
My brother in law has them on a 416 motor he’s been 10.50 with them so I guess they work ok have heard rumors there coming out with a off set pushrod head but who knows
Re: Trick Flow Sml Blk Heads [Re: scottb] #2841842
11/04/20 07:39 PM
11/04/20 07:39 PM
HellsGate
outcast Offline OP
outcast  Offline OP
HellsGate
Thanks for your help . This car well be a track car only Again thanks for your help...
Re: Trick Flow Sml Blk Heads [Re: outcast] #2841930
11/04/20 09:37 PM
11/04/20 09:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What about Indy?
Re: Trick Flow Sml Blk Heads [Re: justinp61] #2842025
11/05/20 05:25 AM
11/05/20 05:25 AM
HellsGate
outcast Offline OP
outcast  Offline OP
HellsGate
what do they have that well work on this engine.. Thanks
Re: Trick Flow Sml Blk Heads [Re: outcast] #2842054
11/05/20 09:14 AM
11/05/20 09:14 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Both the 360-1 and 360-2 heads Indy makes will make more power than the Trick Flows.
Just go to Indy’s site and read up on them
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Trick Flow Sml Blk Heads [Re: B3422W5] #2842281
11/05/20 08:33 PM
11/05/20 08:33 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
If you are buying a complete top end, the Indy heads would be worth considering. They use offset rockers
Alan Jones
Re: Trick Flow Sml Blk Heads [Re: outcast] #2842298
11/05/20 09:03 PM
11/05/20 09:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have ported 360-1's on my 434, not the best numbers I've seen by far but it runs decent. Street/strip 69 Dart, pump 93, 6.25 @ 110 on pump 93 at 3350#. I wouldn't anything less on 440".
