Re: Trick Flow Sml Blk Heads
[Re: outcast]
#2842054
11/05/20 09:14 AM
11/05/20 09:14 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
what do they have that well work on this engine.. Thanks Both the 360-1 and 360-2 heads Indy makes will make more power than the Trick Flows. Just go to Indy’s site and read up on them
[Re: outcast]
#2842298
11/05/20 09:03 PM
11/05/20 09:03 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
what do they have that well work on this engine.. Thanks I have ported 360-1's on my 434, not the best numbers I've seen by far but it runs decent. Street/strip 69 Dart, pump 93, 6.25 @ 110 on pump 93 at 3350#. I wouldn't anything less on 440".
