300C twin turbo engine #2835425
10/21/20 06:13 AM
10/21/20 06:13 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I was offered one of these engines thats in an estate sale. Are they any good? I know nothing about the modern Hemi stuff but I've been given first option on it. Is it suitable to make 1000 hp race motor out of or are we talking boat anchor stuff?
Re: 300C twin turbo engine [Re: rebel] #2835445
10/21/20 08:02 AM
10/21/20 08:02 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's a pretty easy target with a set of rods, pistons, and boost.
- Stu Harmon
Re: 300C twin turbo engine [Re: feets] #2836698
10/23/20 08:16 PM
10/23/20 08:16 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
So just back from looking at the twin turbo hemi partial project. Can anyone enlighten me to what I have here?
Re: 300C twin turbo engine [Re: rebel] #2836805
10/24/20 02:15 AM
10/24/20 02:15 AM
Cab_Burge Online work
Cab_Burge  Online Work
Does it come with any warrenty on it being able to run or was it removed due to needing fixing? work
Lots of parts missing on that motor shruggy
Re: 300C twin turbo engine [Re: Cab_Burge] #2836827
10/24/20 08:34 AM
10/24/20 08:34 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I would look at that as the beginnings of a twin turbo/EFI kit that will bolt to a Gen 3 hemi and I would assume the one it is bolted to is junk until proven otherwise.
Kevin
Re: 300C twin turbo engine [Re: Twostick] #2836862
10/24/20 10:52 AM
10/24/20 10:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
This comes to mind...
Re: 300C twin turbo engine [Re: Twostick] #2836863
10/24/20 10:53 AM
10/24/20 10:53 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Kevin
I agree with that assessment. It appears to be an engine that came off the no guarantee pile at a junk yard to use to mock up the turbo system. It may or may not be a usable core. It kind of looks like someone spent an hour bolting on the major parts and then quit. It wasn't rusty enough so they set it outside for a couple years. Could be a good start on an expensive project.
Re: 300C twin turbo engine [Re: rebel] #2837227
10/25/20 11:23 AM
10/25/20 11:23 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you can get it cheap then go for it. Don't expect it to fit under a hood.
The turbos and engine may be cores and may still work. You won't know until you get it home and take it apart. Someone has some time in that intake.
- Stu Harmon
Re: 300C twin turbo engine [Re: rebel] #2837239
10/25/20 11:55 AM
10/25/20 11:55 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
1320 Video posted this bad boy in IG today!
Twin Turbo Magnum
Re: 300C twin turbo engine [Re: gsmopar] #2837666
10/26/20 05:32 PM
10/26/20 05:32 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
looks like a intake and a couple of turbos
The motor appears to be stock
