Oil in Carb?
#2836003
10/22/20 10:18 AM
10/22/20 10:18 AM
Posts: 1,534 Florida
CHRGR69
While tearing down my carb for a rebuild, I notice what appears to be oil. Not a lot, but very sticky/tacky and dark brown. This carb sat for over 5 years from the last start up with ethanol gas.
Grandma always said I had "hands of gold"!
Re: Oil in Carb?
[Re: CHRGR69]
#2836032
10/22/20 11:26 AM
10/22/20 11:26 AM
RapidRobert
ethanol causes alot of problems even in a DD
Re: Oil in Carb?
[Re: Sniper]
#2836055
10/22/20 12:11 PM
10/22/20 12:11 PM
CHRGR69
More gas/varnish than anything else
Re: Oil in Carb?
[Re: CHRGR69]
#2836083
10/22/20 01:15 PM
10/22/20 01:15 PM
Posts: 12,092 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In the float bowl? If so, it would seem hard for engine oil to end up there on a running engine. Besides, I have seen that kind of varnish/residue before in carbs that have sat with fuel in them. Top end cleaner is about the best stuff I have found to clean up that mess. Sometimes it's called de-carbon, sometimes even tune-up-in-a-can. But it is the only stuff that my outboard service schools would recommend for carb cleaning and it is still the only thing I use on carbs. No carburetor cleaner, it's just too harsh.
Master, again and still
Re: Oil in Carb?
[Re: CHRGR69]
#2836127
10/22/20 02:48 PM
10/22/20 02:48 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Is this in the throttle bores and venturi or inside the fuel bowls ?
