Oil in Carb? #2836003
10/22/20 10:18 AM
10/22/20 10:18 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
While tearing down my carb for a rebuild, I notice what appears to be oil. Not a lot, but very sticky/tacky and dark brown. This carb sat for over 5 years from the last start up with ethanol gas.
Grandma always said I had "hands of gold"!
Re: Oil in Carb? [Re: CHRGR69] #2836032
10/22/20 11:26 AM
10/22/20 11:26 AM
ethanol causes alot of problems even in a DD
Re: Oil in Carb? [Re: RapidRobert] #2836038
10/22/20 11:36 AM
10/22/20 11:36 AM
VA
dragon slayer Online content
dragon slayer  Online Content
VA
Don't believe it is oil, but a varnish residue from the old gas.
Re: Oil in Carb? [Re: CHRGR69] #2836043
10/22/20 11:41 AM
10/22/20 11:41 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
This could be reversion and maybe a valley pan leak
Re: Oil in Carb? [Re: Clanton] #2836047
10/22/20 11:48 AM
10/22/20 11:48 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Could be from the PCV circuit, but based on the sticky comment I'd think gas myself. What's it smell like?
Re: Oil in Carb? [Re: Sniper] #2836055
10/22/20 12:11 PM
10/22/20 12:11 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
More gas/varnish than anything else
Re: Oil in Carb? [Re: CHRGR69] #2836083
10/22/20 01:15 PM
10/22/20 01:15 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
In the float bowl? If so, it would seem hard for engine oil to end up there on a running engine. Besides, I have seen that kind of varnish/residue before in carbs that have sat with fuel in them. Top end cleaner is about the best stuff I have found to clean up that mess. Sometimes it's called de-carbon, sometimes even tune-up-in-a-can. But it is the only stuff that my outboard service schools would recommend for carb cleaning and it is still the only thing I use on carbs. No carburetor cleaner, it's just too harsh.
Master, again and still
Re: Oil in Carb? [Re: DaveRS23] #2836086
10/22/20 01:21 PM
10/22/20 01:21 PM
moparx Offline
moparx  Offline
in the float bowls, it's varnish/residue from the old gas.
looking down through the venturi's, it more than likely is a combination of gas residue and reversion particles.
beer
Re: Oil in Carb? [Re: CHRGR69] #2836127
10/22/20 02:48 PM
10/22/20 02:48 PM
Is this in the throttle bores and venturi or inside the fuel bowls ?
