Re: 300C twin turbo engine
[Re: rebel]
#2835445
10/21/20 08:02 AM
10/21/20 08:02 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That's a pretty easy target with a set of rods, pistons, and boost.
[Re: Twostick]
#2836863
10/24/20 10:53 AM
10/24/20 10:53 AM
Posts: 4,754 Moved to N.E. Tennessee
GomangoCuda
I would look at that as the beginnings of a twin turbo/EFI kit that will bolt to a Gen 3 hemi and I would assume the one it is bolted to is junk until proven otherwise.
Kevin
I agree with that assessment. It appears to be an engine that came off the no guarantee pile at a junk yard to use to mock up the turbo system. It may or may not be a usable core. It kind of looks like someone spent an hour bolting on the major parts and then quit. It wasn't rusty enough so they set it outside for a couple years. Could be a good start on an expensive project.
[Re: rebel]
#2837227
10/25/20 11:23 AM
10/25/20 11:23 AM
feets
Senior Management
Senior Management
Irving, TX
If you can get it cheap then go for it. Don't expect it to fit under a hood.
The turbos and engine may be cores and may still work. You won't know until you get it home and take it apart. Someone has some time in that intake.
