Meziere Water Pump with Alternator #2826587
09/29/20 07:14 PM
09/29/20 07:14 PM
portland, ct
Since1822 Offline OP
portland, ct
Any pics and or ideas that you have for mounting an alternator with a meziere water pump with no motor plate. I have a chance to get one from a friend-the one piece unit not the bolt in to original housing one. I am currently running a stock setup with a 440 source pump and 7 blade fan. Blew the belt off at track this weekend so I plan to go to electric fans and pump. Any help is much appreciated. Thanks
Re: Meziere Water Pump with Alternator [Re: Since1822] #2826652
09/29/20 08:53 PM
09/29/20 08:53 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have the same issue. I have the 120 amp Denso alternator. I will be making a bracket for the alternator. Also plan on o-ringing the Meziere pump to block so I don't need to use gaskets. Not sure on the crank pulley yet.
Re: Meziere Water Pump with Alternator [Re: Since1822] #2826655
09/29/20 09:03 PM
09/29/20 09:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Then what I did might be what your looking for.......A-body's are narrow and I could not fit it lower, The plate gos right around it.
Re: Meziere Water Pump with Alternator [Re: markz528] #2826656
09/29/20 09:05 PM
09/29/20 09:05 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Meziere Water Pump with Alternator [Re: bigdad] #2826682
09/29/20 10:28 PM
09/29/20 10:28 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by bigdad
Anyone have an installed picture?
Re: Meziere Water Pump with Alternator [Re: markz528] #2826840
09/30/20 11:39 AM
09/30/20 11:39 AM
lansing mi.
e85mope Offline
e85mope  Offline
lansing mi.
Kinda hard to see , but I use the DMI bracket
Re: Meziere Water Pump with Alternator [Re: markz528] #2826852
09/30/20 12:13 PM
09/30/20 12:13 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I can't get picture either its hid behind everything
Re: Meziere Water Pump with Alternator [Re: bigdad] #2827165
10/01/20 12:29 AM
10/01/20 12:29 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Not the best pic angle for the bracket but it's all I have in files. Could take a better pic if you need.
Was in the process of changing form a Meziere back to crank driven in 1st pic. Older DMI bracket tho.
Re: Meziere Water Pump with Alternator [Re: Since1822] #2827223
10/01/20 08:56 AM
10/01/20 08:56 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
You should be able to come up w/ some spacers to keep the stock alternator and bracket w/ that pump and just use a shorter belt.
If not, I'd also suggest the DMI bracket and a small one wire alternator.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Meziere Water Pump with Alternator [Re: thehemikid] #2827253
10/01/20 09:53 AM
10/01/20 09:53 AM
portland, ct
portland, ct
Appreciate the pics and info thanks !
Re: Meziere Water Pump with Alternator [Re: Since1822] #2827262
10/01/20 10:08 AM
10/01/20 10:08 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Here are a couple of the DMI mount.
69 GTX 68 Road Runner
Re: Meziere Water Pump with Alternator [Re: JERICOGTX] #2827264
10/01/20 10:10 AM
10/01/20 10:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
All I can find. Our dragster piece
Re: Meziere Water Pump with Alternator [Re: JERICOGTX] #2827265
10/01/20 10:14 AM
10/01/20 10:14 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Engine looks fantastic. Super sanitary!
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Meziere Water Pump with Alternator [Re: B3422W5] #2827293
10/01/20 10:59 AM
10/01/20 10:59 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Re: Meziere Water Pump with Alternator [Re: PolyDart] #2830401
10/08/20 02:23 PM
10/08/20 02:23 PM
Here's the DMI bracket
CHIP
Re: Meziere Water Pump with Alternator [Re: an8sec70cuda] #2830564
10/08/20 09:06 PM
10/08/20 09:06 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Here's a friend setup coming off the fuel block off plate
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
