Re: Meziere Water Pump with Alternator
[Re: Since1822]
#2826652
09/29/20 08:53 PM
09/29/20 08:53 PM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
I have the same issue. I have the 120 amp Denso alternator. I will be making a bracket for the alternator. Also plan on o-ringing the Meziere pump to block so I don't need to use gaskets. Not sure on the crank pulley yet.
[Re: bigdad]
#2826682
09/29/20 10:28 PM
09/29/20 10:28 PM
markz528
Morrow, OH
Anyone have an installed picture?
[Re: markz528]
#2826852
09/30/20 12:13 PM
09/30/20 12:13 PM
Posts: 34,867 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Anyone have an installed picture? I can't get picture either its hid behind everything
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Since1822]
#2827223
10/01/20 08:56 AM
10/01/20 08:56 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
You should be able to come up w/ some spacers to keep the stock alternator and bracket w/ that pump and just use a shorter belt. If not, I'd also suggest the DMI bracket and a small one wire alternator.
[Re: Since1822]
#2827262
10/01/20 10:08 AM
10/01/20 10:08 AM
Posts: 10,019 MN
JERICOGTX
MN
Here are a couple of the DMI mount.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2827265
10/01/20 10:14 AM
10/01/20 10:14 AM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
Here are a couple of the DMI mount. Engine looks fantastic. Super sanitary!
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: PolyDart]
#2830401
10/08/20 02:23 PM
10/08/20 02:23 PM
an8sec70cuda
[Re: an8sec70cuda]
#2830564
10/08/20 09:06 PM
10/08/20 09:06 PM
Posts: 1,030 ohio
67mprfan
ohio
Here's a friend setup coming off the fuel block off plate
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
