Re: Meziere Water Pump with Alternator
[Re: Since1822]
#2826652
09/29/20 08:53 PM
09/29/20 08:53 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I have the same issue. I have the 120 amp Denso alternator. I will be making a bracket for the alternator. Also plan on o-ringing the Meziere pump to block so I don't need to use gaskets. Not sure on the crank pulley yet.
[Re: bigdad]
#2826682
09/29/20 10:28 PM
09/29/20 10:28 PM
markz528
Morrow, OH
Anyone have an installed picture?
[Re: markz528]
#2826852
09/30/20 12:13 PM
09/30/20 12:13 PM
Posts: 34,939 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Anyone have an installed picture? I can't get picture either its hid behind everything
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Since1822]
#2827223
10/01/20 08:56 AM
10/01/20 08:56 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
You should be able to come up w/ some spacers to keep the stock alternator and bracket w/ that pump and just use a shorter belt. If not, I'd also suggest the DMI bracket and a small one wire alternator.
[Re: Since1822]
#2827262
10/01/20 10:08 AM
10/01/20 10:08 AM
Posts: 10,044 MN
JERICOGTX
MN
Here are a couple of the DMI mount.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2827265
10/01/20 10:14 AM
10/01/20 10:14 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Here are a couple of the DMI mount. Engine looks fantastic. Super sanitary!
[Re: PolyDart]
#2830401
10/08/20 02:23 PM
10/08/20 02:23 PM
an8sec70cuda
[Re: an8sec70cuda]
#2830564
10/08/20 09:06 PM
10/08/20 09:06 PM
Posts: 1,030 ohio
67mprfan
ohio
Here's a friend setup coming off the fuel block off plate
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
