Re: Properly been asked a 1000 times
[Re: 70Challengerse]
#2821748
09/16/20 11:17 PM
09/16/20 11:17 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I remember removing the sway bar on a 1968 or 1969,CRS, GTX. It was held on the A arms by two small diameter rods, one on each side and two clamps held onto the K member by two 5/16 or 3/8 bolts. What I'm saying is you need the tabs on the A arms, you could make your own and weld them on or have someone do that for you, drilling the two holes in the K member for the clamps is no big deal Isn't there several different vendors offering sway bar kits for those cars now?
#2821752
09/16/20 11:31 PM
09/16/20 11:31 PM
Posts: 30,997 Oregon
AndyF
Have a 68 Coronet , I want a k-frame that has a org sway bar set -up , what fits and what do I need to make it work? thanks V8 K frame I assume? If so, any B body K frame from 1967 to 1972 would bolt in there. Most K frame are predrilled for the sway bar but not a lot of the lower control arms have the tabs on them. Original sway bar stuff is a little hard to come by so unless you are doing a perfect restoration you might want to go aftermarket. If you have some fab skills you can add a sway bar to your existing K frame. If you are going to change the K frame then I'd suggest finding a 1970 to 1972 since the anti-sway bar on them was tucked inside the K. The '67 to '69 sway bar hung down and really long arms. Good luck, it can be a chore to find all the parts for a conversion. Too bad the factory didn't make the anti-sway bar a standard feature back then.
[Re: Jim_Lusk]
#2821871
09/17/20 12:45 PM
09/17/20 12:45 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
"Properly been asked a 1000 times"....... Oh least if not more: Jules the Wiperman until he passed away, and Stephan Fournier ( SF Restorations) took over his business of wiper motor restoration. He will restore your wiper motor to perfection!
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2821886
09/17/20 01:07 PM
09/17/20 01:07 PM
Posts: 8,866 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
"Properly been asked a 1000 times"....... Oh least if not more: Jules the Wiperman until he passed away, and Stephan Fournier ( SF Restorations) took over his business of wiper motor restoration. He will restore your wiper motor to perfection! ???? Who said anything about wiper motors ????
[Re: Stanton]
#2821905
09/17/20 02:12 PM
09/17/20 02:12 PM
Posts: 5,999 Salem
Grizzly
Salem
Oh, gosh. Sorry about that, just seen the title and did a quick reply. To answer your question, you can expect anywhere from 15 to 16mpg empty from a Cummins Dodge.
Mo' Farts
