Properly been asked a 1000 times #2821744
09/16/20 11:05 PM
09/16/20 11:05 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Have a 68 Coronet , I want a k-frame that has a org sway bar set -up , what fits and what do I need to make it work? thanks
Re: Properly been asked a 1000 times [Re: 70Challengerse] #2821748
09/16/20 11:17 PM
09/16/20 11:17 PM
I remember removing the sway bar on a 1968 or 1969,CRS, GTX. It was held on the A arms by two small diameter rods, one on each side and two clamps held onto the K member by two 5/16 or 3/8 bolts. What I'm saying is you need the tabs on the A arms, you could make your own and weld them on or have someone do that for you, drilling the two holes in the K member for the clamps is no big deal twocents
Isn't there several different vendors offering sway bar kits for those cars now? scope up
Re: Properly been asked a 1000 times [Re: 70Challengerse] #2821752
09/16/20 11:31 PM
09/16/20 11:31 PM
AndyF Offline
AndyF  Offline
V8 K frame I assume? If so, any B body K frame from 1967 to 1972 would bolt in there. Most K frame are predrilled for the sway bar but not a lot of the lower control arms have the tabs on them. Original sway bar stuff is a little hard to come by so unless you are doing a perfect restoration you might want to go aftermarket. If you have some fab skills you can add a sway bar to your existing K frame. If you are going to change the K frame then I'd suggest finding a 1970 to 1972 since the anti-sway bar on them was tucked inside the K. The '67 to '69 sway bar hung down and really long arms. Good luck, it can be a chore to find all the parts for a conversion. Too bad the factory didn't make the anti-sway bar a standard feature back then.
Re: Properly been asked a 1000 times [Re: AndyF] #2821760
09/17/20 12:18 AM
09/17/20 12:18 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
K-member should already have the holes. If not, just drill them. Sway bar tabs for the lower control arms can be bought or fabbed.
Re: Properly been asked a 1000 times [Re: Jim_Lusk] #2821871
09/17/20 12:45 PM
09/17/20 12:45 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
"Properly been asked a 1000 times".......
Oh least if not more: Jules the Wiperman until he passed away, and Stephan Fournier (SF Restorations) took over his business of wiper motor restoration.
He will restore your wiper motor to perfection! up
Mo' Farts
Moderated by "tbagger".
Re: Properly been asked a 1000 times [Re: Grizzly] #2821886
09/17/20 01:07 PM
09/17/20 01:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
???? Who said anything about wiper motors ????
Re: Properly been asked a 1000 times [Re: Stanton] #2821905
09/17/20 02:12 PM
09/17/20 02:12 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Oh, gosh. Sorry about that, just seen the title and did a quick reply.
To answer your question, you can expect anywhere from 15 to 16mpg empty from a Cummins Dodge. up
Mo' Farts
Re: Properly been asked a 1000 times [Re: Stanton] #2822000
09/17/20 06:00 PM
09/17/20 06:00 PM
Thanks for the replies , found a 70 with sway bar setup... up
Re: Properly been asked a 1000 times [Re: 70Challengerse] #2822030
09/17/20 07:36 PM
09/17/20 07:36 PM
AndyF Offline
AndyF  Offline
A 70 with sway bar would work really nice. Did you get the matching lower control arms? The nice thing about the '70 style is that the anti-sway bar is tucked out of the way so it doesn't interfere with disc brake calipers. The motor mounts should be the same so it should be a bolt in operation.
Re: Properly been asked a 1000 times [Re: AndyF] #2822219
09/18/20 11:49 AM
09/18/20 11:49 AM
Yes a complete set up.... up
