Green treated lumber #2820325
09/13/20 06:04 PM
09/13/20 06:04 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
I have a 2x8 and a 2x10. What I need is a 2x6. If I rip them down to the size I need is the "new" exposed edge no longer considered green treated? Local store is all sold out of the 2x6. Just trying to use up what I have laying around
Re: Green treated lumber [Re: blaze] #2820329
09/13/20 06:13 PM
09/13/20 06:13 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
The treatment doesn't penetrate the wood completely from all sides so once you rip the 2x8 to 2x6, the side you cut won't be treated.
You should be able to buy the treatment and brush it on the exposed side.
Mike.
Re: Green treated lumber [Re: moparmike1] #2820334
09/13/20 06:22 PM
09/13/20 06:22 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
Thank-you
Re: Green treated lumber [Re: blaze] #2820341
09/13/20 06:48 PM
09/13/20 06:48 PM
Delta BC, Canada
Baller Offline
Baller  Offline
Delta BC, Canada
What you need is either Zinc Naphthenate or Copper Naphthenate. The copper will be green in color if matching is important. Many different brands available.
1970 GTX, work in progress...
Re: Green treated lumber [Re: Baller] #2820345
09/13/20 07:01 PM
09/13/20 07:01 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
Cool, Thanks
Re: Green treated lumber [Re: blaze] #2820355
09/13/20 07:49 PM
09/13/20 07:49 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yep
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Green treated lumber [Re: blaze] #2820438
09/13/20 10:38 PM
09/13/20 10:38 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
It's mainly arsenic. Your wife may have some.....go check the spice rack! eek runaway
Re: Green treated lumber [Re: JDMopar] #2820535
09/14/20 10:21 AM
09/14/20 10:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Thompsons Water Seal works great and is a lot less harmful to your health. That green "End Cut Treatment" is not friendly to most living creatures.
Re: Green treated lumber [Re: Stanton] #2820635
09/14/20 02:19 PM
09/14/20 02:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Green treated lumber [Re: moparmike1] #2820711
09/14/20 05:51 PM
09/14/20 05:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Mike.
I thought the point of "pressure treated" was that solved that penetration issue. I have yet to see much of a color difference with viewing a cross section of cut to length PT board.
Are we talking about "new" eco friendly treated wood?
The green brush on copper/arsenic treatments I believe are no longer available for sale to the public, or very restricted.
My thinking was, the OP had no real concerns to be worried about.
Re: Green treated lumber [Re: jcc] #2820738
09/14/20 07:11 PM
09/14/20 07:11 PM
moparmike1 Offline
moparmike1  Offline
Mike.
Based on my experience, the pressure treatment penetrates the surface just enough so that it looks good from the outside. But once a cut is made, you'll see the untreated inner section.
All I can say is, if you cut a pressure treated board, you might want to seal that cut with similar treatment to hold off the rot as long as possible.
Mike.
Re: Green treated lumber [Re: moparmike1] #2820763
09/14/20 08:04 PM
09/14/20 08:04 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I built a construction skid sign out of PT wood years ago and after one winter the wood touching the ground was 100% rotted out. A can of Krylon would have been a better moisture barrier than that stuff was.
Re: Green treated lumber [Re: Neil] #2820772
09/14/20 08:24 PM
09/14/20 08:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't think the stuff was ever intended to sit directly on soil.. Even fence posts that are just planted in the post hole will rot out in a few years. The stuff is fine if used where it gets an opportunity to dry out. At one time it was a big thing to build basement walls (exterior) with PT lumber BUT they still applied a water barrier to the exterior surface.
Re: Green treated lumber [Re: Stanton] #2820778
09/14/20 08:32 PM
09/14/20 08:32 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
If its something not connected to the house and I have no pt and ive a few days I just take a small paint brush and a gallon of old oil mixed with a pint of diesel and brush it on, over and over and let it keep soaking.
Its my way of recycling up
STOP POTATO HATE!
Re: Green treated lumber [Re: Stanton] #2820795
09/14/20 08:56 PM
09/14/20 08:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes, I knew because of it sitting on the ground that is wasn't going to last forever. It seemed like it rotted out faster than un-treated wood would have. It literally crumbled apart when I went to move it and these were 4x4 sized pieces. I bought the PT stuff thinking it would be at least a little more durable.
Re: Green treated lumber [Re: Baller] #2820800
09/14/20 09:01 PM
09/14/20 09:01 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Careful with this stuff also as it stains your hands for a couple of days.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Green treated lumber [Re: JDMopar] #2821151
09/15/20 03:42 PM
09/15/20 03:42 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
You....know, now that you say that, I have been feeling a little funny
