Who are you guys using to port your heads? #2816151
09/02/20 10:20 AM
09/02/20 10:20 AM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Good Morning guys, I think I'm going to end up having to port my own heads but I figured I should pose the question anyone here as to who you guys are using to get your heads ported. I have a set of BGE heads I need to have ported for my engine. I'm always costs minded so if you guys don't mind, please add the cost as well. Thanks, any help is appreciated. The head will be a max effort deal, so opening the throat up to max, keeping velocities up is going to be a must.
-Adriel
Adriel Paradise
Substation Design Engineer III
Re: Who are you guys using to port your heads? [Re: Adrielp] #2816214
09/02/20 12:51 PM
09/02/20 12:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I do not have a Gen III yet but Ray Meyers will port mine when I get it. Ray Meyers SixpackGut on here and Born Again Hot Rods on FaceBook and Instagram
68 Barracuda Formula S 340
Re: Who are you guys using to port your heads? [Re: Adrielp] #2816502
09/02/20 10:26 PM
09/02/20 10:26 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I had Ray port mine. It was a while ago so not sure what the cost is now. Give him a call he is a good guy.
Re: Who are you guys using to port your heads? [Re: RTSE4ME] #2816566
09/03/20 08:58 AM
09/03/20 08:58 AM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
Ray Meyers- problem solved smile
Re: Who are you guys using to port your heads? [Re: w2stroker] #2816720
09/03/20 03:45 PM
09/03/20 03:45 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Ray has a Hot Rod Drag Week winning Barracuda coupe with a GIII hemi so his experience with this engine is very real.
Re: Who are you guys using to port your heads? [Re: w2stroker] #2816856
09/03/20 11:10 PM
09/03/20 11:10 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Ditto....now if I could only find a 6.1 block.
Re: Who are you guys using to port your heads? [Re: Dragula] #2821094
09/15/20 01:49 PM
09/15/20 01:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Try member 70B5Cuda here on the board. He parts out a lot of late model SRT8 cars. I can get you his personal info and phone if you can't get ahold of him using his username.
'63 Dodge 330
11.19 @ 121 mph
Re: Who are you guys using to port your heads? [Re: Dragula] #2864552
12/25/20 03:37 AM
12/25/20 03:37 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Re: Who are you guys using to port your heads? [Re: Adrielp] #2865024
12/26/20 07:24 PM
12/26/20 07:24 PM
SoCal
Brian Hafliger Offline
SoCal
If nothing pans out, we also port the Gen3 Hemi heads with great results...
Brian
IMM Engines
Brian Hafliger
Re: Who are you guys using to port your heads? [Re: Brian Hafliger] #2865488
12/27/20 10:22 PM
12/27/20 10:22 PM
K
Kiddart Offline
Kiddart  Offline
K
They have a really good Gen 3 hemi CNC Program
katechengines.com
Thank you
Kiddart
Re: Who are you guys using to port your heads? [Re: 52savoy] #2885630
02/08/21 06:28 PM
02/08/21 06:28 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
Originally Posted by 52savoy
I think those are actually 5.7 hemi blocks.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: Who are you guys using to port your heads? [Re: Adrielp] #2885633
02/08/21 06:32 PM
02/08/21 06:32 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
My Uncle did my Eagles , but Ray Meyers name comes up a lot when it comes to good flowing G3 heads , In Delaware there's a shop called performance injection equipment who have the best flowing 03-08 heads not sure if they do any Apache or Eagle head work.
Re: Who are you guys using to port your heads? [Re: Adrielp] #2921650
05/12/21 01:08 PM
05/12/21 01:08 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Thitek. Craig is truly a game changer!
Re: Who are you guys using to port your heads? [Re: Bubba] #2922637
05/14/21 10:39 PM
05/14/21 10:39 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
We have a 6.4 CNC program that makes good power.
4B569BA2-19FB-4F90-A2F8-F04EBB07E809.jpegA7E7A0BF-D1E2-4D50-85F8-F3C3D6BB3CA2.jpeg55979DA6-2372-496B-A750-CA21BF452604.jpeg40CCA56E-2581-4DFA-A8EC-A8D540F2976C.jpeg
Re: Who are you guys using to port your heads? [Re: Adrielp] #2928797
05/31/21 09:46 AM
05/31/21 09:46 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
Yesterday I got to see a set of KATECH BGE CNC heads put a 25hp beating on a set of MMX ported CNC heads on a 431ci BGE block build , both test were using Comp cams Stage 3 HRT 228/236 , Edelbrock Intake dyno headers (1 7/8) 90mm TB Holleys Terminator EFI set up......FWIW the MMX were 10 hp better then Frankenstein Apache heads.
