Who are you guys using to port your heads?
#2816151
09/02/20 10:20 AM
09/02/20 10:20 AM
Posts: 577 Arkansas
Adrielp
Arkansas
Good Morning guys, I think I'm going to end up having to port my own heads but I figured I should pose the question anyone here as to who you guys are using to get your heads ported. I have a set of BGE heads I need to have ported for my engine. I'm always costs minded so if you guys don't mind, please add the cost as well. Thanks, any help is appreciated. The head will be a max effort deal, so opening the throat up to max, keeping velocities up is going to be a must.
-Adriel
Adriel Paradise Substation Design Engineer III
Re: Who are you guys using to port your heads?
[Re: Adrielp]
#2816214
09/02/20 12:51 PM
09/02/20 12:51 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I do not have a Gen III yet but Ray Meyers will port mine when I get it. Ray Meyers SixpackGut on here and Born Again Hot Rods on FaceBook and Instagram
68 Barracuda Formula S 340
[Re: Dragula]
#2821094
09/15/20 01:49 PM
09/15/20 01:49 PM
Posts: 4,669 Wichita
GY3
Wichita
Ray Meyers- problem solved Ditto....now if I could only find a 6.1 block. Try member 70B5Cuda here on the board. He parts out a lot of late model SRT8 cars. I can get you his personal info and phone if you can't get ahold of him using his username.
[Re: Adrielp]
#2865024
12/26/20 07:24 PM
12/26/20 07:24 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
If nothing pans out, we also port the Gen3 Hemi heads with great results... Brian IMM Engines
Brian Hafliger
[Re: Brian Hafliger]
#2865488
12/27/20 10:22 PM
12/27/20 10:22 PM
Posts: 1,550 Michigan
Kiddart
They have a really good Gen 3 hemi CNC Program
katechengines.com
Thank you Kiddart
[Re: 52savoy]
#2885630
02/08/21 06:28 PM
02/08/21 06:28 PM
Posts: 70 Souderton
Taylor
Souderton
I think those are actually 5.7 hemi blocks.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi 2020 1320 Challenger....stock daily driver.
[Re: Adrielp]
#2885633
02/08/21 06:32 PM
02/08/21 06:32 PM
Posts: 70 Souderton
Taylor
Souderton
My Uncle did my Eagles , but Ray Meyers name comes up a lot when it comes to good flowing G3 heads , In Delaware there's a shop called performance injection equipment who have the best flowing 03-08 heads not sure if they do any Apache or Eagle head work.
[Re: Adrielp]
#2928797
05/31/21 09:46 AM
05/31/21 09:46 AM
Posts: 70 Souderton
Taylor
Souderton
Yesterday I got to see a set of KATECH BGE CNC heads put a 25hp beating on a set of MMX ported CNC heads on a 431ci BGE block build , both test were using Comp cams Stage 3 HRT 228/236 , Edelbrock Intake dyno headers (1 7/8) 90mm TB Holleys Terminator EFI set up......FWIW the MMX were 10 hp better then Frankenstein Apache heads.
