Re: Issues with Cragar S/S lug nuts [Re: NITROUSN] #2815683
08/31/20 09:28 PM
08/31/20 09:28 PM
BlueRacer69 Offline OP
Originally Posted by NITROUSN
Maybe you need these with the larger shank diameter. these are .684 where the ones you are trying to use are .592. Did you ever call Cragar to verify what nuts you need for the wheels you have? Exactly what wheel did you buy? I see two styles series 08/61 S/S and 61C S/S.
CRR-27721-4
Hey NITROUSN, I bought the series 08/61 S/S Cragar mags, and I bought the .592 shank diameter lug nuts. But I think I should of maybe went with the bigger .684 diameter shank instead. But the .592's is the ones the seller said fit the 5 on 4" small Cragar bolt circle. One of the first things I noticed when I tested the first mag wheel on my Dart was the lug nut seemed slightly sloppy in mag hole. Now I'm thinking of ordering another set of lug nuts with the .684 diameter shank and see if those fit better. Wish me luck.
Re: Issues with Cragar S/S lug nuts [Re: BlueRacer69] #2815864
09/01/20 01:22 PM
09/01/20 01:22 PM
moparx Offline
moparx  Offline
i may have missed it, but what size hole do your wheels have ?
beer
Re: Issues with Cragar S/S lug nuts [Re: moparx] #2815920
09/01/20 05:02 PM
09/01/20 05:02 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i don't see a picture of the mags or the lug nuts in question but here is my take on it..take the lug nut i am assuming with the shank on it and stick it thru the mag wheel hole..it should not be sticking past the back flange or even close to it to bottom out on the drum or hub assembly ...next take the lug nut and screw it into the stud to make sure it did not bottom out inside the lug nut before it reaches the drum and you don't have a lot of treads left sticking out..and does it use a washer? the lug nut i think is your problem..they might not be deep enough inside and they bottom out on the tip of the stud..cutting the lug nut shorter only shortens the length going into the mag wheel hole..but the inside is still too short..just saying
Re: Issues with Cragar S/S lug nuts [Re: AARCONV] #2816058
09/02/20 12:05 AM
09/02/20 12:05 AM
I had the lug nuts shorten at a local machine shop because they were to long and not allowing the mag wheel to tighten down against the brake drum. Now they tighten down good but loosen back up after a few miles. I think the shanks of the lug nuts are a little to small for the bolt holes. Just my thinking. shruggy
Re: Issues with Cragar S/S lug nuts [Re: BlueRacer69] #2816123
09/02/20 08:42 AM
09/02/20 08:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
They might need to be shorter. I cut my own w/o issue. Have you taken the wheel off and put the nut in the hole to see if it is still too long? How much of the wheel stud sticks out w/o a thread? I do know you should use the specific washers, but that usually applies to uni-lug. Perhaps if you took some of the chrome off the back side of the washers that might help. Something is up, I'd expect a few to loosen up but not all 20.
Coming soon!!!!
Re: Issues with Cragar S/S lug nuts [Re: Mr.Yuck] #2816197
09/02/20 12:06 PM
09/02/20 12:06 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
you have the wrong shank diam. lug nuts. When you put cragars on a 7/16 stud there is a special extra thick shank lug nut. It has the same outside dia. of a 1/2 inch lug. These are both 7/16-20
Re: Issues with Cragar S/S lug nuts [Re: BlueRacer69] #2818115
09/07/20 10:58 AM
09/07/20 10:58 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Well were you able to solve the problem??
Re: Issues with Cragar S/S lug nuts [Re: NITROUSN] #2818197
09/07/20 03:07 PM
09/07/20 03:07 PM
moparx Offline
moparx  Offline
i'm curious as well.
problem issues being resolved with posted results help all of us. up
beer
Re: Issues with Cragar S/S lug nuts [Re: NITROUSN] #2818342
09/07/20 09:01 PM
09/07/20 09:01 PM
I think I solve the problem for now (maybe). Here is what I've done as of this posting. I've removed all the Cragar S/S lug nuts from the mags because they just would not stay tight. Then I replaced them with 7/16-20 acorn style nuts with the taper ends. Yes the same type lug nuts that is used on the Mopar Ralley Wheels. I've only driven the car a couple of times since trying these nuts, but they seem to be working and staying tight so far on the Cragar Mags. Who knew this would work. More time and some longer trips with the car will tell the true story.
Re: Issues with Cragar S/S lug nuts [Re: BlueRacer69] #2818357
09/07/20 09:51 PM
09/07/20 09:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
In order for a tapered seat lug nut to work the wheels need to have tapered seats. If they do not what you are doing is dangerous. Cragar has SS wheels with tapered seats.
Re: Issues with Cragar S/S lug nuts [Re: NITROUSN] #2818360
09/07/20 09:56 PM
09/07/20 09:56 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Are you sure your wheels are not the 61C/SS these take a tapered seat lug nut. Bottom one on the chart. 61C/SS
Re: Issues with Cragar S/S lug nuts [Re: NITROUSN] #2818704
09/08/20 07:14 PM
09/08/20 07:14 PM
Hey NITROUSN, You may have just hit the nail on the head. I went and found the invoice from Summit Racing that came with the Cragar Mags. Here's the part number on the invoice: CRR-61C4654 14X6 5on4 S/S Cragar. It looks like they are the 61C type mags after all. So this type of Cargar S/S wheel takes & uses a tapered seat lug nut. Stupid Me, I've been trying to use the old school style Cragar lug nuts with the shank ends. No wonder they kept coming loose on me. Thank you everyone for all the input. Looks like problem solved. up
Re: Issues with Cragar S/S lug nuts [Re: BlueRacer69] #2818717
09/08/20 08:19 PM
09/08/20 08:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That was your problem. Summit lists it with conical seat.
Brand: Cragar
Manufacturer's Part Number: 1421908402B
Part Type: Wheels
Product Line: Cragar 61C Series S/S Super Sport Chrome Wheels
Summit Racing Part Number: CRR-61C4654
UPC: 038244248575
Wheel Diameter: 14 in.
Wheel Width (in): 6.000 in.
Wheel Bolt Pattern (app): 5 x 101.6mm
5 x 4 in.
Wheel Material: Steel/Aluminum
TPMS Sensor Compatible: Yes
Primary Wheel Color: Chrome
Wheel Finish: Chrome
Manufacturers Wheel Series: Cragar S/S Super Sport Series
Backspacing (in): 3.500 in.
Offset: 0.00mm
Wheel Construction: 2-piece
Beadlock Included: No
Beadlock Functional: No
Lug Nut Seat Style: Conical seat - 60 degree
Re: Issues with Cragar S/S lug nuts [Re: NITROUSN] #2818722
09/08/20 08:26 PM
09/08/20 08:26 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Never heard of a 5x4 Cragar with a conical seat, must be something new. I wonder when they started making them and why? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Issues with Cragar S/S lug nuts [Re: Mr.Yuck] #2818871
09/09/20 10:05 AM
09/09/20 10:05 AM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
Originally Posted by Mr.Yuck
They might need to be shorter. I cut my own w/o issue. ...
How did you cut them? I'm facing the same problem with some AR Mags and left hand lug nuts. Don't want to use the local machine shop if not necessary.
Re: Issues with Cragar S/S lug nuts [Re: SuperRob] #2819202
09/10/20 09:00 AM
09/10/20 09:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Cut off tool with a GOOD thin wheel. If you don't have air, you could use a grinder with a good thin wheel, or a ban saw.
Coming soon!!!!
Re: Issues with Cragar S/S lug nuts [Re: Mr.Yuck] #2819278
09/10/20 12:14 PM
09/10/20 12:14 PM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
Thanks. I have a straight grinder that should work with a thin wheel.
