D A shocks #2814600
08/29/20 03:15 AM
08/29/20 03:15 AM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
On D A shocks, which setting has the most choices?
Re: D A shocks [Re: 72sat] #2814633
08/29/20 09:34 AM
08/29/20 09:34 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
You mean what brand or extension and rebound? They usually have equal number adjustments in both directions.
Re: D A shocks [Re: 72sat] #2814665
08/29/20 11:08 AM
08/29/20 11:08 AM
The Afco double adjustable coil over shocks I bought last year have 36 adjustments on them, 18 each way up
Re: D A shocks [Re: Cab_Burge] #2814717
08/29/20 01:22 PM
08/29/20 01:22 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Pretty Sure the Santhuff ones have more ext adjustment than compression.
Re: D A shocks [Re: Tig] #2814766
08/29/20 03:09 PM
08/29/20 03:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends on whos it is.
Re: D A shocks [Re: Cab_Burge] #2815435
08/31/20 11:22 AM
08/31/20 11:22 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
And, in addition to the choices it comes with; you can send them in to the manufacturer and have the entire range of adjustments shifted farther up or down by the place that built them. I had to do that on my Afco's to get more extension restriction.
Re: D A shocks [Re: jbc426] #2815628
08/31/20 06:35 PM
08/31/20 06:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The AFCO Big Gun valving in a new shock is a good value. Cheaper than having a new 3850 upgraded.
Anymore, if it's goes into the 10s, especially if it's heavy or a clutch car, I would put a Big Gun level or custom shock on it.
