Hurst shifter question #2815148
08/30/20 04:04 PM
08/30/20 04:04 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I have a hurst 7236 shift handle, could I get it to work with the comp plus shifter I have for my 68 Charger?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hurst shifter question [Re: astjp2] #2815171
08/30/20 05:57 PM
08/30/20 05:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So I take it your shifter is a bayonet type unit and the shift lever is a bolt on stick. You can install a bolt on stick receiver in your current shifter housing or I have seen sticks modified to fit a bayonet type receiver. I think the bolt ion deal is a much better choice and you also freshen it up when you swap in the new parts twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Hurst shifter question [Re: fourgearsavoy] #2815182
08/30/20 06:46 PM
08/30/20 06:46 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I was more wondering if it would interfere with the seat or things like that . Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hurst shifter question [Re: astjp2] #2815205
08/30/20 07:35 PM
08/30/20 07:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is that stick the one with a bunch of noddle bends it like the stock bench seat handle or is it flat with a bunch of bends side ways to clear the consoles?
One way to find out, that or a picture would help us see it work grin
Re: Hurst shifter question [Re: Cab_Burge] #2815210
08/30/20 07:50 PM
08/30/20 07:50 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Pretty straight side to side
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hurst shifter question [Re: astjp2] #2815289
08/30/20 11:05 PM
08/30/20 11:05 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I also have a 7926
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hurst shifter question [Re: astjp2] #2815310
08/31/20 01:43 AM
08/31/20 01:43 AM
That one looks like the earl, pre 1966, B body shifter with no console twocents
Re: Hurst shifter question [Re: astjp2] #2815311
08/31/20 01:44 AM
08/31/20 01:44 AM
I don't think that one will work with a bench seat, buckets only with no console twocents
Re: Hurst shifter question [Re: Cab_Burge] #2815364
08/31/20 08:57 AM
08/31/20 08:57 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Charger has buckets
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hurst shifter question [Re: astjp2] #2815380
08/31/20 09:51 AM
08/31/20 09:51 AM
New York
rarefish Offline
rarefish  Offline
New York
The intended application of the #7236 handle is 1967-69 Camaro 1968-72 Chevelle.
I think it would be too short for a 68 Charger.
Re: Hurst shifter question [Re: rarefish] #2815389
08/31/20 10:12 AM
08/31/20 10:12 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I've personally used the #7236 handle (1967-69 Camaro 1968-72 Chevelle) in a 1969 GTX- buckets, no console- and it does not work well. Basically, 2nd gear has the stick into the driver's seat.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Hurst shifter question [Re: EWJ] #2815390
08/31/20 10:13 AM
08/31/20 10:13 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, Great, at least I now know what I am into, I will have to look at the other one and see if it fits. I think its from a 72 A body.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hurst shifter question [Re: EWJ] #2815692
08/31/20 09:57 PM
08/31/20 09:57 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
***CORRECTION***
I tried an 8022, not a 7236- and it was not a good fit.
Sorry for the mis-information here.
Ed
Re: Hurst shifter question [Re: EWJ] #2815897
09/01/20 03:42 PM
09/01/20 03:42 PM
Dysart,Pa.
K
kork340 Offline
kork340  Offline
K
Dysart,Pa.
The 7926 is for A-Body I believe.
