Is the 5.7 in the Dakota an earlier or later engine, and was the 877 still on pump gas? Either way I'm glad someone tried opening the ring gap and pushing it, not sure if others have as I don't follow super close, but its neat that someone tried it and told the world. Maybe it won't live long at 877 WHP, but if it will take that it will probably live a while dialed back to 600 WHP, especially if they added meth injection or used 110+ fuel. The fact is even if the G3 won't live at 500 or 600 RWHP with the cheap turbos there are other guys doing it with LS junk yard engines. And you could put forged pistons in the 5.7 for another 1K and eliminate that as the weak point. I wish I could find a G3 for 250 bucks though, THAT is the part I find un-realistic.
Even if they dialed that all the way back to 500 WHP, which it made on 5 PSI, you're likely going to have a lot into any NA engine to make that power, 440, Hemi, G3, or otherwise. You could always boost a 440 though. Or spray it. The funny thing is the stock G3 Hemi has a stronger block and supposedly weak pistons, the 440s block isn't as strong but I bet those OEM pistons could take a ton of abuse. The real problem for a budget build is the nature of a 50 year old engine is you're just not likely to find a good 440 cheap. Although I see people asking 2K for G3s on ebay anyway, so maybe the typical cost closer than it would seem. One day there won't be any LS truck engines in the junk yard either, and there won't be any junk yard turbo 5.3s either.
I think the answer really depends on the budget, and what you define as ideal. If I needed an aftermarket block and/or was going to spend 15K or more I'm with Joel, I would go G2 Hemi.
Also where is someone getting the 5.7 for $250? Is that typical? What is the going rate for a junk yard 5.7 near everyone else? It seems to be like 2K near me.
Engine had 265,000 miles on it - still does, why it was $250 and its an early version 06 (15 years old). The 5.7 heads out flow the 5.3 LS so its going to do almost everything better, not to mention more cubes. Cheap 5.7's aren't hard to find guys, been building them en masse since 2003. Gap rings, head studs, bearing if you care and let it eat.
Re: What is the ideal Street/Strip Engine these days?
[Re: SRT6776]
#2813347 08/25/2011:20 PM08/25/2011:20 PM
The in car video of him driving it and getting on it did not impress me at all Do you know how much they had detuned it down after he tested it? I've had a bunch of street and strip cars, from mid 12.s to my current 2850 Lb. S/P car that runs high 8s at 150.+ MPH in the 1/4. My last pump gas car, (3450 Lb. with me in it) Duster ran 10.00s a bunch of times through the muffs with the air cleaner on That motor made 727 HP with 680 Ft. Lbs. torque It was a hoot to drive on the street, I had to be real careful whenever I went to WOT
[Re: Cab_Burge]
#2813372 08/26/2001:44 AM08/26/2001:44 AM
You've had some bad azz rides and very quick, its just gotten easier. A G3 hemi head flows more than any traditional sb/bb, 392 6.4 outflows a G2 426. If guys like you tinkered with a gen 3 we could get this really moving.
[Re: SRT6776]
#2813434 08/26/2008:54 AM08/26/2008:54 AM
This kid seriously has me reconsidering my BB's. I'm tempted to pull the trigger on a couple Gen 3's and selling all of my BB stuff.
eBay-cdwmotorsports
[Re: SRT6776]
#2813448 08/26/2009:25 AM08/26/2009:25 AM
Prices in my area...
[Re: cdwmotorsports]
#2813492 08/26/2010:55 AM08/26/2010:55 AM
I doubt I will build a BB again.
[Re: SRT6776]
#2813495 08/26/2011:06 AM08/26/2011:06 AM
Yep!
Maybe not the gospel below, but a starting point and (from what I've seen) fairly realistic numbers:
Not me C.I. rule My last pump gas BB 517 C.I. stroker motor made 775 HP with a set of 440-1 heads and changing the heads to a set of Indy M.W. SR made 727 HP with a single 1050 CFM Dominator That combination pushed my old 3450Lb. Duster to a best ET of 9.993 at 134.+ MPH corked up with the air cleaner on using 91 octane Oregon pump swill
