Page 3 of 3 1 2 3
Re: What is the ideal Street/Strip Engine these days? [Re: justinp61] #2813090
08/25/20 02:14 PM
08/25/20 02:14 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Originally Posted by justinp61
If I were starting over and could afford it I'd use all Gen 3 stuff, n/a or boosted. If I couldn't afford the Gen 3 I'd go junkyard LS.
iagree
Re: What is the ideal Street/Strip Engine these days? [Re: Mr.Yuck] #2813267
08/25/20 08:44 PM
08/25/20 08:44 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Originally Posted by Mr.Yuck
Originally Posted by SRT6776
877 WHP turbo $250 junkyard 2006 5.7 hemi
love the truck but 'aint now way (unless he owns the yard) you can build a 9 second motor that cheap.
Well get new glasses, because you just saw it
Re: What is the ideal Street/Strip Engine these days? [Re: GTX MATT] #2813269
08/25/20 08:50 PM
08/25/20 08:50 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
Originally Posted by GTX MATT
Is the 5.7 in the Dakota an earlier or later engine, and was the 877 still on pump gas? Either way I'm glad someone tried opening the ring gap and pushing it, not sure if others have as I don't follow super close, but its neat that someone tried it and told the world. Maybe it won't live long at 877 WHP, but if it will take that it will probably live a while dialed back to 600 WHP, especially if they added meth injection or used 110+ fuel. The fact is even if the G3 won't live at 500 or 600 RWHP with the cheap turbos there are other guys doing it with LS junk yard engines. And you could put forged pistons in the 5.7 for another 1K and eliminate that as the weak point. I wish I could find a G3 for 250 bucks though, THAT is the part I find un-realistic.
Even if they dialed that all the way back to 500 WHP, which it made on 5 PSI, you're likely going to have a lot into any NA engine to make that power, 440, Hemi, G3, or otherwise. You could always boost a 440 though. Or spray it. The funny thing is the stock G3 Hemi has a stronger block and supposedly weak pistons, the 440s block isn't as strong but I bet those OEM pistons could take a ton of abuse. The real problem for a budget build is the nature of a 50 year old engine is you're just not likely to find a good 440 cheap. Although I see people asking 2K for G3s on ebay anyway, so maybe the typical cost closer than it would seem. One day there won't be any LS truck engines in the junk yard either, and there won't be any junk yard turbo 5.3s either.
I think the answer really depends on the budget, and what you define as ideal. If I needed an aftermarket block and/or was going to spend 15K or more I'm with Joel, I would go G2 Hemi.
Also where is someone getting the 5.7 for $250? Is that typical? What is the going rate for a junk yard 5.7 near everyone else? It seems to be like 2K near me.
Engine had 265,000 miles on it - still does, why it was $250 and its an early version 06 (15 years old). The 5.7 heads out flow the 5.3 LS so its going to do almost everything better, not to mention more cubes. Cheap 5.7's aren't hard to find guys, been building them en masse since 2003. Gap rings, head studs, bearing if you care and let it eat.
Re: What is the ideal Street/Strip Engine these days? [Re: SRT6776] #2813347
08/25/20 11:20 PM
08/25/20 11:20 PM
The in car video of him driving it and getting on it did not impress me at all shruggy
Do you know how much they had detuned it down after he tested it?
I've had a bunch of street and strip cars, from mid 12.s to my current 2850 Lb. S/P car that runs high 8s at 150.+ MPH in the 1/4.
My last pump gas car, (3450 Lb. with me in it) Duster ran 10.00s a bunch of times through the muffs with the air cleaner on boogie That motor made 727 HP with 680 Ft. Lbs. torque shruggy
It was a hoot to drive on the street, I had to be real careful whenever I went to WOT devil hammer haha
Re: What is the ideal Street/Strip Engine these days? [Re: Cab_Burge] #2813372
08/26/20 01:44 AM
08/26/20 01:44 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
You've had some bad azz rides and very quick, its just gotten easier. A G3 hemi head flows more than any traditional sb/bb, 392 6.4 outflows a G2 426. If guys like you tinkered with a gen 3 we could get this really moving.
Re: What is the ideal Street/Strip Engine these days? [Re: SRT6776] #2813434
08/26/20 08:54 AM
08/26/20 08:54 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
This kid seriously has me reconsidering my BB's. I'm tempted to pull the trigger on a couple Gen 3's and selling all of my BB stuff.
eBay-cdwmotorsports
Re: What is the ideal Street/Strip Engine these days? [Re: SRT6776] #2813448
08/26/20 09:25 AM
08/26/20 09:25 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Prices in my area...
Re: What is the ideal Street/Strip Engine these days? [Re: cdwmotorsports] #2813492
08/26/20 10:55 AM
08/26/20 10:55 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I doubt I will build a BB again.
'63 Dodge 330
11.19 @ 121 mph
Re: What is the ideal Street/Strip Engine these days? [Re: SRT6776] #2813495
08/26/20 11:06 AM
08/26/20 11:06 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep!
Maybe not the gospel below, but a starting point and (from what I've seen) fairly realistic numbers:
https://www.hotrod.com/articles/ccrp-1210-inside-the-g3-hemi-cylinder-head/
Rich H.
Esse Quam Videri
Re: What is the ideal Street/Strip Engine these days? [Re: cdwmotorsports] #2813522
08/26/20 11:53 AM
08/26/20 11:53 AM
Not me tsk C.I. rule devil
My last pump gas BB 517 C.I. stroker motor made 775 HP with a set of 440-1 heads and changing the heads to a set of Indy M.W. SR made 727 HP with a single 1050 CFM Dominator work That combination pushed my old 3450Lb. Duster to a best ET of 9.993 at 134.+ MPH corked up with the air cleaner on using 91 octane Oregon pump swill shruggy
Page 3 of 3 1 2 3
