70 B-body Hardtop Door Glass Flocked Seal Install #2807697
08/11/20 01:46 PM
08/11/20 01:46 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Hello,
How do the flocked seals get installed on the chrome strip on the rear portion of the window? Is there a trick to sliding the seals down in the trim piece or do they get pushed in from the long edge? I have already ruined a couple pairs. It seems the flocking starts to come off super easy in chunks ruining the piece. I am wondering if I am doing something wrong. Would love some helpfull install tips! Here is the part in mind: https://www.detroitmuscletechnologi...arter-window-leading-edge-seals-flocked/
Jeff
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: Cuda340] #2807739
08/11/20 03:27 PM
08/11/20 03:27 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I experienced the same issue....the flocking material is very easily damaged by any contact with the door or guide. Not sure it is a problem with your install. I believe it is a material/durability issue. I was pretty bumbed out to see this after a couple of times running the windows up and down. Not sure how long the originals lasted.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: 70gtx440dana] #2807984
08/12/20 09:48 AM
08/12/20 09:48 AM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Do you recall how you installed them?
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: Cuda340] #2807998
08/12/20 10:22 AM
08/12/20 10:22 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, the original stuff lasted a long time.
Hardtops I restored in the '90s showed little to no wear on them, and I re-used most of them.
(Last several cars since have been coupes or early B wagons.)
Maybe the glues & flocking now are not as good due to regulations ?
I'd call the manufacturer; the DMT stuff I recently bought was excellent.
Also, I haven't had any flocking problems on the sweeps/weatherstrips at the belt areas, or sedan run channels.
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: topside] #2808005
08/12/20 10:32 AM
08/12/20 10:32 AM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
I talked with Jim at DMT and also Metro who is the supplier. They both are great vendors, but couldn't really give me installation guidance. So I am reaching out to you guys for install tips.
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: Cuda340] #2808007
08/12/20 10:42 AM
08/12/20 10:42 AM
Lansing, MI
Lansing, MI
Don't remember exact steps.The install into the stainless was pretty simple. By the time I had my door and quarter glass adjusted (not a simple process) the flocking was damaged on both sides. Maybe the trick is using old seals to make the glass the adjustments....then install the new seals after glass is 99% adjusted.
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: Cuda340] #2808343
08/13/20 09:48 AM
08/13/20 09:48 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Go to www.moparconnectionmagazine.com. Under "Tech" header go to the "Restoration section" on page two there is a step by step "How to" with detailed pictures on restoring these using the currently available felt gliders.
It will save you a whole lotta grief with these parts.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: MOPARMIKE69] #2808344
08/13/20 09:50 AM
08/13/20 09:50 AM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Awresome Thanks!!!!!!!!!
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: Cuda340] #2808345
08/13/20 09:54 AM
08/13/20 09:54 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
In re-reading your post I may have thought you meant the glass sliders into the vent wing. If you mean the rubber felt covered chrome strip seal I just lube the channel with WD 40 and slide the seal in from the bottom. Hopefully these will help you get on down the road.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: MOPARMIKE69] #2808851
08/14/20 01:17 PM
08/14/20 01:17 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Yeah I looked at the Mopar action article and it mentions the front ones, which I have to install anyways. But I am having a hard time sliding the rear seals in the chrome channel . I will give WD-40 a shot. I am going to try it on a messed up one to see if I can get it to work without the flock coming off.
Thanks,
Jeff
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: Cuda340] #2808899
08/14/20 02:52 PM
08/14/20 02:52 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I contacted Metro. even spoke with them today about this. Had a 2nd customer complain about the flocking peeling off near one of the ends. My contact at Metro said he would pass that info on to their QC guy.
I haven't had any complaints before so hoping this is a new issue but as a reseller not sure how to address it? Do I return 40 sets and hope they dont just send them back as "a new batch"? Do I open every bag and try to damage them to check - what a gigantic waste of time that would be to make $2? Personally I thing I'd just get the plain ones. On E bodies the 70 cars got flocked then 71-74 ONLY got the plain rubber ones. Think they did that for cost savings. On the A & B bodies I have never been able to nail down why/when they go flocked over plain. Again I'd just go with plain. In fact I may just sell the plain ones. I definitely dont want to sell a problematic product and there is no margin in them to have to do QC on my end.
PS I'm curious how these are installed too.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 70 B-body Hardtop Door Glass Flocked Seal Install [Re: 71TA] #2809777
08/17/20 02:18 PM
08/17/20 02:18 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Hello Jim,
I am still going to give it another shot. Did you happen to ship them out yet? I have one that's perfect. If not give me a call. Jeff Hammer
