70 B-body Hardtop Door Glass Flocked Seal Install
#2807697
08/11/20 01:46 PM
08/11/20 01:46 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Hello, How do the flocked seals get installed on the chrome strip on the rear portion of the window? Is there a trick to sliding the seals down in the trim piece or do they get pushed in from the long edge? I have already ruined a couple pairs. It seems the flocking starts to come off super easy in chunks ruining the piece. I am wondering if I am doing something wrong. Would love some helpfull install tips! Here is the part in mind: https://www.detroitmuscletechnologi...arter-window-leading-edge-seals-flocked/Jeff
Re: 70 B-body Hardtop Door Glass Flocked Seal Install
[Re: Cuda340]
#2807739
08/11/20 03:27 PM
08/11/20 03:27 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I experienced the same issue....the flocking material is very easily damaged by any contact with the door or guide. Not sure it is a problem with your install. I believe it is a material/durability issue. I was pretty bumbed out to see this after a couple of times running the windows up and down. Not sure how long the originals lasted.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: Cuda340]
#2808007
08/12/20 10:42 AM
08/12/20 10:42 AM
70gtx440dana
Lansing, MI
Do you recall how you installed them? Don't remember exact steps.The install into the stainless was pretty simple. By the time I had my door and quarter glass adjusted (not a simple process) the flocking was damaged on both sides. Maybe the trick is using old seals to make the glass the adjustments....then install the new seals after glass is 99% adjusted.
[Re: Cuda340]
#2808343
08/13/20 09:48 AM
08/13/20 09:48 AM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Go to www.moparconnectionmagazine.com. Under "Tech" header go to the "Restoration section" on page two there is a step by step "How to" with detailed pictures on restoring these using the currently available felt gliders. It will save you a whole lotta grief with these parts.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Cuda340]
#2808345
08/13/20 09:54 AM
08/13/20 09:54 AM
MOPARMIKE69
Nashville, TN
In re-reading your post I may have thought you meant the glass sliders into the vent wing. If you mean the rubber felt covered chrome strip seal I just lube the channel with WD 40 and slide the seal in from the bottom. Hopefully these will help you get on down the road.
