Oil pressure varying causes, Milidon inlet hose Update #2807138
08/10/20 01:57 AM
08/10/20 01:57 AM
Cab_Burge Offline OP
I had a incident two weeks ago where I cause my oil pan to hit on the return road at Medford drag strip causing it to leak bad enough to not be able to run it again before having it welded up. It is a older Hamburger SS big block 10 quart pan with a large kick out, it had been repaired before I got it and needed the drag link tube removed before I could use it with the Lee Smith Engr. dual line swinging pickup, which increase the capacity by several more quarts.
I had used one #12 AN Milidon SS hose for one of the pickups and used Fragola fittings and there black lined hose for the other longer pickup hose to go to the front of the Milidon oil pump fitting.
The SS hose is fairly short and not easy to install and get both fittings hooked up, it has worked well until I removed it to fix the pan. After fixing the pan( I put 10 quarts in it) the oil pressure would go up to 60 lbs.(normally goes to 80 lbs. cold with 10W30Wt ZR1 oil in it) and then start to drop down after running for 15 to 20 seconds , it was headed towards to zero so I shut it off and check the high pressure bypass valve and spring to see if it was getting stuck, it wasn't.
The upper SS hose was slowly leaking oil out of it dropping down onto the lower Fragola black hose making me think at first it was leaking oil out of the valve cover gasket but it wasn't. I started the motor up several times more and it would do the same thing after running a short period, I shut it off and it would be fine for 15 to 20 seconds when I ran it again and them start to loose pressure, it finally hit me that the short upper hose would start sucking air into it where it was leaking after it suck all the oil away from the leak so it could suck air easier shock shruggy I must have broke one of the SS wires poking a hole through the lining into the center causing the leak rant whiney
I'll replace that hose with another Fragola hose after I get the fittings I need to make it wrench
I hate Murphy rant
See my last post on this issue for the updates
Re: Oil pressure varying causes, Milidon inlet hose [Re: Cab_Burge] #2807152
08/10/20 07:04 AM
08/10/20 07:04 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I have had old SS braided hose de-laminate internally and suck closed. Probably whats happening.
Re: Oil pressure varying causes, Milidon inlet hose [Re: Cab_Burge] #2807180
08/10/20 09:39 AM
08/10/20 09:39 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Will you test the oil system with a priming rod?
Re: Oil pressure varying causes, Milidon inlet hose [Re: Clanton] #2807255
08/10/20 12:37 PM
08/10/20 12:37 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I keep a piece of delaminated hose in my office for show and tell with customers. Almost cost me a very nice hemi a few years back.
Todd
Re: Oil pressure varying causes, Milidon inlet hose [Re: Clanton] #2807265
08/10/20 01:06 PM
08/10/20 01:06 PM
No, it is leaking oil when sitting so I'm assuming it not going to stop leaking. I'll make another hose to replace it wrench
Re: Oil pressure varying causes, Milidon inlet hose [Re: Cab_Burge] #2807276
08/10/20 01:33 PM
08/10/20 01:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know where the hose is mounted but if its after the pump all of that is under pressure
so it its hard to get it to suck closed... I should have asked is it the suction side or pressure side
wave
Re: Oil pressure varying causes, Milidon inlet hose [Re: MR_P_BODY] #2807284
08/10/20 01:49 PM
08/10/20 01:49 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Damn a rubber hose use Teflon
Re: Oil pressure varying causes, Milidon inlet hose [Re: cudaman1969] #2807380
08/10/20 05:37 PM
08/10/20 05:37 PM
The hose is real short on that pickup so teflon lined hose is not useable due to being not flexable (SP?) enough to make the curve up to fitting on the oil pump with out kinking.
I made the new hose a little longer( 1 1/2 to 2/0 inches longer) hoping that will help, if it doesn't I'll shorten it to the same length as the old hose luck
Re: Oil pressure varying causes, Milidon inlet hose [Re: Cab_Burge] #2807456
08/10/20 09:00 PM
08/10/20 09:00 PM
fredericksburg,va
fredericksburg,va
Mine bent on a 90*
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: cudaman1969] #2807512
08/10/20 11:29 PM
08/10/20 11:29 PM
I replace the swinging oil pickup hose along with having a small weep hole welded up on the pan and reinstall both.
No leaking from either one boogie
Oil pressure went back to 80 Lbs. steady idling and rock steady pressure for over a minute boogie
I took a picture of the new longer hose installed on the motor scope, I was very careful to not kink it due to it being another new Milidon SS hose I forgot I had blush
Racing this weekend, hopefully luck
This oil pan has been through the war, more than once whistling grin
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: Cab_Burge] #2807571
08/11/20 08:15 AM
08/11/20 08:15 AM
an8sec70cuda Offline
So how long are you guys seeing these braided hoses last before they have internal issues?
I've had one braided fuel line start leaking after about 12 or 13 years of use.
I'm still using the same external oil pickup braided line I put on my car in 2003. I have not noticed any issues w/ it, but now I'm thinking maybe it's time to change it anyway.
Same w/ my trans cooler lines...regular -6an braided steel, not ptfe. Been on the car since somewhere around 2003 or 2004 I think.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: an8sec70cuda] #2807682
08/11/20 01:28 PM
08/11/20 01:28 PM
I've not heard of any PTFE hoses failing while in use and not bent, twisted or damaged some other way work
I owned and maintain my small airplane, 1960 piper Comanche 250, for 16 yrs. Never had any problems with any hose on it but they do have a recommended life span on them and the FAA says you need to follow it, same thing on commercial aircraft but probably a higher, stricter standard shruggy
The rubber line hoses will fail with use or even while setting on the shelf due to age shock shruggy
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: Cab_Burge] #2807765
08/11/20 04:28 PM
08/11/20 04:28 PM
New York, USA
Chargerfan68 Offline
New York, USA
I know i must be crazy....but believe it or not, i have steel braided heater hoses that were installed in 1978. Not kidding. Never leaked. Now i have to change them bc i jinxed myself. These come from the Grumman airplane manufacturer. Grumman is/was 20 min from me and where my car came from. So i always thought their quality was probably higher than the braided hose speed parts one could get. Who knows. But 42 years, and no leaks is insane. Thought you’d get a kick out of that.
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: Chargerfan68] #2807777
08/11/20 04:53 PM
08/11/20 04:53 PM
fredericksburg,va
fredericksburg,va
I will be using the best one out there on my external lines just for the safety part, are steel fittings in place of aluminum made for these lines?
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: cudaman1969] #2807806
08/11/20 06:30 PM
08/11/20 06:30 PM
Hydraulic fittings ( JCC or JC maybe)use the same thread count and pitch as AN fittings up scope
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: Cab_Burge] #2807809
08/11/20 06:37 PM
08/11/20 06:37 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
* J.I.C.
Google “parker fitting catalog 4300”
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: an8sec70cuda] #2813916
08/27/20 12:20 PM
08/27/20 12:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
5 years in the aviation world and then they are suspect. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Oil pressure varying causes, Milidon inlet hose Update [Re: Cab_Burge] #2813917
08/27/20 12:21 PM
08/27/20 12:21 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
JIC, joint industry council
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
