Axle seals #2806521
08/08/20 11:25 AM
08/08/20 11:25 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Just want to make sure, the metal axle seal, the raised rib part Faces inward?
RS23L7 4-Speed
Re: Axle seals [Re: Mopar_Mike] #2806590
08/08/20 03:06 PM
08/08/20 03:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What rear end??? A pic of both sides of the seal would help to avoid any confusion. beer
Re: Axle seals [Re: Mopar_Mike] #2806595
08/08/20 03:14 PM
08/08/20 03:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The seal lip always faces the oil.
Re: Axle seals [Re: John_Kunkel] #2806600
08/08/20 03:25 PM
08/08/20 03:25 PM
Danville, NH
Danville, NH
Thanks John, I meant the thin metal gasket that goes on the outside of the axle, over the five studs. It has a raised rib around it on the inner circle, just don't know if it faces towards the axle or towards the backing plate.
RS23L7 4-Speed
Re: Axle seals [Re: Mopar_Mike] #2806632
08/08/20 05:04 PM
08/08/20 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you mean the embossed steel gasket that goes between the housing and the backing plate, it doesn't matter.
Re: Axle seals [Re: John_Kunkel] #2806645
08/08/20 05:30 PM
08/08/20 05:30 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Dr. Diff told me the embossed raised rib goes towards the axle when I did mine.
Re: Axle seals [Re: Suregrip391] #2806853
08/09/20 01:26 PM
08/09/20 01:26 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I always install the steel gasket's rib against the housing end.
