Axle seals
#2806521
08/08/20 11:25 AM
08/08/20 11:25 AM
Posts: 4,282 Danville, NH
Mopar_Mike
Danville, NH
Just want to make sure, the metal axle seal, the raised rib part Faces inward?
RS23L7 4-Speed
Re: Axle seals
[Re: John_Kunkel]
#2806600
08/08/20 03:25 PM
08/08/20 03:25 PM
Mopar_Mike
Danville, NH
Thanks John, I meant the thin metal gasket that goes on the outside of the axle, over the five studs. It has a raised rib around it on the inner circle, just don't know if it faces towards the axle or towards the backing plate.
RS23L7 4-Speed
Re: Axle seals
[Re: Mopar_Mike]
#2806632
08/08/20 05:04 PM
08/08/20 05:04 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you mean the embossed steel gasket that goes between the housing and the backing plate, it doesn't matter.
Re: Axle seals
[Re: John_Kunkel]
#2806645
08/08/20 05:30 PM
08/08/20 05:30 PM
Posts: 1,978 USA
Suregrip391
USA
Dr. Diff told me the embossed raised rib goes towards the axle when I did mine.
