A body big block K member #2803492
07/31/20 10:09 PM
07/31/20 10:09 PM
BigFish69 Offline OP
Does anyone know the value of original 69 440 A body big block K member ?
Re: A body big block K member [Re: BigFish69] #2803498
07/31/20 10:31 PM
07/31/20 10:31 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
What's the difference between a 440 and a 383 '69 A-body K-frame??
Re: A body big block K member [Re: A12] #2803545
08/01/20 01:43 AM
08/01/20 01:43 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Pretty sure that the K-Member is exactly the same, the left side engine mount bracket that bolts to the engine is different between a 383 and a 440.
The WIW section would be the best place to ask about what it's worth. twocents
https://www.engine-swaps.com/Pages/ProductsType/K-Frames.html
Re: A body big block K member [Re: SNK-EYZ] #2803602
08/01/20 09:46 AM
08/01/20 09:46 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I just bought two of them, one a k-frame in excellent shape with the 383 motor mounts at $500 and the second a complete set-up with all suspension, brakes, torsion bars, and the unique sway bar with manual steering box for $1000. Of course I would not sell them for what I paid for them, so it really depends on what you have as far as what comes with it. Another factor is if it is a 67 k-frame it is worth quite a bit less due to the one year only idler arm mount, those usually go for $350-400 bare... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: A body big block K member [Re: Rhinodart] #2803609
08/01/20 10:21 AM
08/01/20 10:21 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I love it when I hear my junk went up in value
Had one at a mopar swap meet for sale, I was standing off the side and heard an older gent tell his buddy that It was a made up one and not real, had to laugh
Re: A body big block K member [Re: cudaman1969] #2803944
08/01/20 08:40 PM
08/01/20 08:40 PM
Its from 1969 M code 440 Cuda with motor mounts. its for sale if anyone has any interest in it.
Re: A body big block K member [Re: BigFish69] #2803996
08/01/20 10:50 PM
08/01/20 10:50 PM
I'm pretty sure that the one year only 440 A body K member is NOT the same as my 1969 A body OEM 383 K member confused scope
I have only seen one stock M code stock 440 motor A body and it had a altogether different drivers side front motor mount on it, not anywhere near close to looking like my stock 1969 383 drivers side mount confused shruggy
What say you, Rhinodart on this?
Re: A body big block K member [Re: Cab_Burge] #2803999
08/01/20 11:14 PM
08/01/20 11:14 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
the K-frame is the same
the engine side of the driver's side motor mount is different 383 (bolts to front of block just below head) VS. 440 (bolts to oil pump bosses lower on block)
Re: A body big block K member [Re: 6bblgt] #2804002
08/01/20 11:27 PM
08/01/20 11:27 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
383 and 440 k-members are the same. The 440 drivers side motor mount is actually a 383 mount that was bent out and an angle iron piece welded on.
A-Body's RULE!
Re: A body big block K member [Re: Rhinodart] #2804068
08/02/20 09:18 AM
08/02/20 09:18 AM
blewbyu Offline
blewbyu  Offline
K frames are the same like Rhino said only DS mount different.
Re: A body big block K member [Re: blewbyu] #2804186
08/02/20 01:38 PM
08/02/20 01:38 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
VS. 383
Re: A body big block K member [Re: 6bblgt] #2804471
08/02/20 08:15 PM
08/02/20 08:15 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Just curious, but is the M code block different than a regular 440?
Re: A body big block K member [Re: fastmark] #2804482
08/02/20 09:51 PM
08/02/20 09:51 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
nothing different, other than 2 holes drilled & tapped in the oil pump boss scope
Re: A body big block K member [Re: 6bblgt] #2804484
08/02/20 10:01 PM
08/02/20 10:01 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
BUT ..........
I recently came across this "industrial block based" 1969 E 440 HP prior MOPARTS thread
old stroker 440 race car engine - obliterated VIN but has bosses that would allow the 383 A-body mount to be used & dated appropriately for the first batches of 440 GTS and/or 'cudas - a former owner raced a 1969 440 'cuda work
moparts-E440-mounting-bosses.jpgmoparts-E440-12-7-HP.jpgmoparts-E440.jpgmoparts-E440-8-5-68.jpg
Re: A body big block K member [Re: 6bblgt] #2804575
08/03/20 08:50 AM
08/03/20 08:50 AM
VA
dragon slayer Offline
VA
Those bosses are in a different position then the ones you showed in the picture above it. So did those "industrial blocks" have a different casting to include those bosses?
Re: A body big block K member [Re: dragon slayer] #2804590
08/03/20 09:57 AM
08/03/20 09:57 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would think so, ever see a pass car 440 with that many ribs? Long time ago I picked up a 426 industrial block out of a60 ton crane to use for my damaged Max Wedge block. Very thick walls and better iron. The stocker guys look for these blocks.
Re: A body big block K member [Re: cudaman1969] #2804606
08/03/20 10:41 AM
08/03/20 10:41 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
And a real Mr. Norms M-Code GSS 440 block, the nicely drilled motor mount holes, and the shaved drivers side rear engine mount...
A-Body's RULE!
Re: A body big block K member [Re: Rhinodart] #2804649
08/03/20 12:17 PM
08/03/20 12:17 PM
VA
VA
Nicely drilled, with no chamfer? wink
Re: A body big block K member [Re: dragon slayer] #2804801
08/03/20 10:29 PM
08/03/20 10:29 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Done on the fly, they didn't waste any time that's for sure! Probably used an angle grinder on the motor mount boss too... laugh2
A-Body's RULE!
Re: A body big block K member [Re: Rhinodart] #2804809
08/03/20 10:43 PM
08/03/20 10:43 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Like others said K frame is the same. I am looking for one. I have one that is pieced together. If its up for sale I am interested.
I am also interested in the bracket. PM sent
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
