Re: A body big block K member
[Re: BigFish69]
#2803498
07/31/20 10:31 PM
07/31/20 10:31 PM
Posts: 21,513 N.E. OHIO, USA
A12
N.E. OHIO, USA
Does anyone know the value of original 69 440 A body big block K member ? What's the difference between a 440 and a 383 '69 A-body K-frame??
[Re: A12]
#2803545
08/01/20 01:43 AM
08/01/20 01:43 AM
Posts: 10,136 A Red State
SNK-EYZ
A Red State
Does anyone know the value of original 69 440 A body big block K member ? What's the difference between a 440 and a 383 '69 A-body K-frame?? Pretty sure that the K-Member is exactly the same, the left side engine mount bracket that bolts to the engine is different between a 383 and a 440. The WIW section would be the best place to ask about what it's worth. https://www.engine-swaps.com/Pages/ProductsType/K-Frames.html
[Re: SNK-EYZ]
#2803602
08/01/20 09:46 AM
08/01/20 09:46 AM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I just bought two of them, one a k-frame in excellent shape with the 383 motor mounts at $500 and the second a complete set-up with all suspension, brakes, torsion bars, and the unique sway bar with manual steering box for $1000. Of course I would not sell them for what I paid for them, so it really depends on what you have as far as what comes with it. Another factor is if it is a 67 k-frame it is worth quite a bit less due to the one year only idler arm mount, those usually go for $350-400 bare...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2803609
08/01/20 10:21 AM
08/01/20 10:21 AM
Posts: 8,271 fredericksburg,va
cudaman1969
fredericksburg,va
I love it when I hear my junk went up in value Had one at a mopar swap meet for sale, I was standing off the side and heard an older gent tell his buddy that It was a made up one and not real, had to laugh
[Re: cudaman1969]
#2803944
08/01/20 08:40 PM
08/01/20 08:40 PM
Posts: 482 Michigan
BigFish69
Its from 1969 M code 440 Cuda with motor mounts. its for sale if anyone has any interest in it.
[Re: BigFish69]
#2803996
08/01/20 10:50 PM
08/01/20 10:50 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
I'm pretty sure that the one year only 440 A body K member is NOT the same as my 1969 A body OEM 383 K member I have only seen one stock M code stock 440 motor A body and it had a altogether different drivers side front motor mount on it, not anywhere near close to looking like my stock 1969 383 drivers side mount What say you, Rhinodart on this?
[Re: 6bblgt]
#2804002
08/01/20 11:27 PM
08/01/20 11:27 PM
Rhinodart
Rhinotruck
Rhinotruck
383 and 440 k-members are the same. The 440 drivers side motor mount is actually a 383 mount that was bent out and an angle iron piece welded on.
A-Body's RULE!
[Re: cudaman1969]
#2804606
08/03/20 10:41 AM
08/03/20 10:41 AM
Rhinodart
Rhinotruck
Rhinotruck
And a real Mr. Norms M-Code GSS 440 block, the nicely drilled motor mount holes, and the shaved drivers side rear engine mount...
A-Body's RULE!
[Re: Rhinodart]
#2804809
08/03/20 10:43 PM
08/03/20 10:43 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
Like others said K frame is the same. I am looking for one. I have one that is pieced together. If its up for sale I am interested. I am also interested in the bracket. PM sent
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
