rod make? #2799739
07/22/20 12:21 PM
07/22/20 12:21 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
QUESTION ? building a 383 for the street looking to get about 400 horses at the wheels my question is can stock rods be used or aftermarket
Re: rod make? [Re: moparsquid] #2799757
07/22/20 12:49 PM
07/22/20 12:49 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
RPM is more of a factor in a 383 than hp. 383’s like to rev, but if you keep it under 6500 the stock rods will be fine. Spin em over 6500 and then you are tempting fate. Shouldn’t have to though, to make that power.
Re: rod make? [Re: Pacnorthcuda] #2799773
07/22/20 01:18 PM
07/22/20 01:18 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
would shot peening them and arp rod bolts help
Re: rod make? [Re: moparsquid] #2799801
07/22/20 01:43 PM
07/22/20 01:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
At 400 hp you are not goin to hit 6500 rpm.
Your stock rods are fine.
Re: rod make? [Re: moparsquid] #2799804
07/22/20 01:52 PM
07/22/20 01:52 PM
Making sure they are sized correctly is important, as is the quality of the engine balance, and not using too heavy of pistons. Basic stuff really. Yeah ARP bolts would be nice.
Re: rod make? [Re: moparsquid] #2799927
07/22/20 06:12 PM
07/22/20 06:12 PM
How long will you be happy with 400 HP at the rear wheels? If forever use stock rods rebuilt, magnafluxed and reconditioned with new ARP replacement rod bolts.
If your thinking of adding more power later replace them now with a better set of BB Chevy type rods and offset grind your crank to increase the stroke a little so it will help you get 400 HP to the rear wheels twocents If you do this you will need a custom made set of pistons also to get the piston deck height and compression ratio the way you will need it to make the power you want to make work
The addiction to power is never ending, usually whistling devil boogie grin
Re: rod make? [Re: Cab_Burge] #2799964
07/22/20 08:19 PM
07/22/20 08:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
440 source 440 Source
3.4K like this · Transportation Service
Jul 15 · · We are making our stock type rods with capscrew bolts in a 383/400 length. Currently in production, expect them on the shelf by the end of the year. Same price. …
Re: rod make? [Re: CSK] #2800005
07/22/20 09:58 PM
07/22/20 09:58 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The rods aren't the weak point in the big block, the rod bolts are. Mopar big blocks have very heavy pistons, yet they used the same size rod bolts as the 318. Rod bolt stretch at high RPMs is what causes most spun rod bearings in our big blocks. Chrysler engineers realized this and used larger rod bolts in the Hemi. Get yourself some ARP high strength rod bolts, use lock tight on the nuts, keep your RPMs under 6,800 and your 383 will be a lot more durable.
Re: rod make? [Re: Cab_Burge] #2800175
07/23/20 11:51 AM
07/23/20 11:51 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks im actally down grading from a 500 strkr max wedge clone to a 383 , a build i always wanted to do i found in the direct connection build its a nhra 343 hp build ,i know its not fast but thats why im building a 64 dodge for the track
Re: rod make? [Re: moparsquid] #2800291
07/23/20 04:03 PM
07/23/20 04:03 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Besides the Eagle and stock rods, Molnar has a 383 rod, but I think it uses the BBC rod journal and probably the pin size as well. Manley has run another set of the Jim Hale Performance rods that are NHRA legal for Stock and SS.
Floyd Lippencott IV
Re: rod make? [Re: mr_340] #2800298
07/23/20 04:14 PM
07/23/20 04:14 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks
Re: rod make? [Re: moparsquid] #2800518
07/24/20 09:10 AM
07/24/20 09:10 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
In my opinion Molnar is a very good choice.
Re: rod make? [Re: 340Cuda] #2800649
07/24/20 02:15 PM
07/24/20 02:15 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
https://www.manciniracing.com/mohrodsetwew.html
Floyd Lippencott IV
Re: rod make? [Re: mr_340] #2801695
07/27/20 12:05 PM
07/27/20 12:05 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
what is the going price and what dealer from thanks
Re: rod make? [Re: moparsquid] #2802018
07/28/20 08:32 AM
07/28/20 08:32 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You can by them direct from Molnar, plus many other vendors just as provided in the link above.
