Re: rod make?
[Re: moparsquid]
#2799804
07/22/20 01:52 PM
07/22/20 01:52 PM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
would shot peening them and arp rod bolts help Making sure they are sized correctly is important, as is the quality of the engine balance, and not using too heavy of pistons. Basic stuff really. Yeah ARP bolts would be nice.
Re: rod make?
[Re: Cab_Burge]
#2799964
07/22/20 08:19 PM
07/22/20 08:19 PM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
440 source 440 Source 3.4K like this · Transportation Service Jul 15 · · We are making our stock type rods with capscrew bolts in a 383/400 length. Currently in production, expect them on the shelf by the end of the year. Same price. …
Re: rod make?
[Re: CSK]
#2800005
07/22/20 09:58 PM
07/22/20 09:58 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
The rods aren't the weak point in the big block, the rod bolts are. Mopar big blocks have very heavy pistons, yet they used the same size rod bolts as the 318. Rod bolt stretch at high RPMs is what causes most spun rod bearings in our big blocks. Chrysler engineers realized this and used larger rod bolts in the Hemi. Get yourself some ARP high strength rod bolts, use lock tight on the nuts, keep your RPMs under 6,800 and your 383 will be a lot more durable.
Re: rod make?
[Re: moparsquid]
#2800291
07/23/20 04:03 PM
07/23/20 04:03 PM
Posts: 3,504 DFW
mr_340
DFW
Besides the Eagle and stock rods, Molnar has a 383 rod, but I think it uses the BBC rod journal and probably the pin size as well. Manley has run another set of the Jim Hale Performance rods that are NHRA legal for Stock and SS.
Floyd Lippencott IV
Re: rod make?
[Re: mr_340]
#2800298
07/23/20 04:14 PM
07/23/20 04:14 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
Besides the Eagle and stock rods, Molnar has a 383 rod, but I think it uses the BBC rod journal and probably the pin size as well. Manley has run another set of the Jim Hale Performance rods that are NHRA legal for Stock and SS. thanks
Re: rod make?
[Re: moparsquid]
#2802018
07/28/20 08:32 AM
07/28/20 08:32 AM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
what is the going price and what dealer from thanks You can by them direct from Molnar, plus many other vendors just as provided in the link above.
