Running/switching to E85
#2799085
07/20/20 07:45 PM
07/20/20 07:45 PM
Superfreak
Superfreak
Well I just recently discovered that a co-op station about 5km from me has E85 so I would really like to run this fuel. I have two Quickfuel 1050 dominator blower carbs that were set for gas.
What is required to be able to run E85?
Thanks.
Re: Running/switching to E85
[Re: ]
#2799174
07/20/20 10:47 PM
07/20/20 10:47 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
My current bracket car had been raced on methanol with a custom fuel system (7.5 gallon custom aluminum fuel cell) mounted up front for a blown B1 motor with a cam driven mechanical injection fuel pump. I put a BG 400 pump between that tank and the motor to run E85 in my 800 HP bracket motor, I used a 100 micron fuel filter between the tank and the pump fed through a #10 AN PTFE Teflon lined stainless steel braided hose and added a 10 micron fuel filter fed through a #10 PTFE line between the pump and the 4 port Magnafuel regulator, I feed the Dominator carb. with # 6 AN PTFE line from the fuel regulator to the fuel bowls, I use .130 stainless steel Holley needles and seats to flow enough E85 into the motor with 5.5 lbs. pressure IHTHs E85 works great for bracket racing
[Re: 69dart]
#2799517
07/21/20 07:22 PM
07/21/20 07:22 PM
Superfreak
Superfreak
Not running the car yet. Hoping to get the rest of my engine parts this week including the heads, which I had to send back to FHO last year due to bad pitting on new castings. Why can't E85 run through a carb that has been set for gas? I am not buying new carbs because between the Canadian peso, shipping and duties that would be another $3500+. I currently have Quickfuel 1050 dominators set up for a roots blower (14-71)
[Re: ]
#2799529
07/21/20 07:50 PM
07/21/20 07:50 PM
Posts: 20,172 Park Forest, IL
slantzilla
Park Forest, IL
A gas carb will run way lean on corn.
